Hola Roberto,
Encontré un problema en el metodo addcolumn del grid. Te adjunto un demo.
El problema se presenta cuando compilo, error de sintaxis . en la linea
Main.Grid_1.AddColumn(i,'Column_'+ALLTRIM(STR(i)), 80 )
Saludos cordiales,
Luis Vasquez.
procedure inicio
load window Main
Main.Center
Main.Activate
PROCEDURE LoadColumn
Main.Grid_1.DeleteColumn(1)
FOR i:= 1 TO 3
Main.Grid_1.AddColumn(i,'Column_'+ALLTRIM(STR(i)), 80)
PROCEDURE LoadData
FOR i:= 1 TO 10
Main.Grid_1.Additem({ 'Element_1', 'Element_2','Element_3' } )
Problem Grid/AddColumn
- luisvasquezcl
Re: Problem Grid/AddColumn
Hola Luis,
This method accepts a four parameters:
FormName.GridName.AddColumn( nColIndex , cCaption , nWidth , nJustify )
Try
Main.Grid_1.AddColumn(i,'Column_'+ALLTRIM(STR(i)), 80,0)
I hope that helps
Try
I hope that helps
- luisvasquezcl
Hi Grigory,
thanks for your help.
We must make a correction in the manual as it appears as optional
Justify value.
<ParentWindowName>. <ControlName>. AddColumn ([nColIndex] , [CCaption], [nWidth], [nJustify])
Luis Vasquez.
Justify value.
Luis Vasquez.
- HMG Founder
Luis, Grigory:luisvasquezcl wrote:Hi Grigory,
Justify value.
Luis Vasquez.
Thanks.
I'll correct the reference ASAP.
