Hello,
The following link is an attempt to explain how to build Harbour 64 Bits
http://mig2soft.com/?p=206
Building Harbour x64 with MinGW x64
- MigSoft
- DBs Used: DBF, MySQL, MariaDB, SQLite, PostgreSQL, FireBird
MigSoft.
MigSoft.
- luisvasquezcl
Re: Building Harbour x64 with MinGW x64
Gracias Miguel,
como siempre con tus buenos aportes.
Espero que te encuentres bien despues del sacudón...
Saludos cordiales,
Luis Vasquez.
Saludos cordiales,
Luis Vasquez.
Nice one. Thanks for sharing MigSoft.
Can you feel the speed difference?
- MigSoft
Gracias Luis, en realidad fue una experiencia muy fuerte, pero sin problemas.
Rathinagiri,
You notice a subtle increase in the speed of the compiled program, I need to do some comparative tests to see results.
The next step is to compile HMG, someone already did
Rathinagiri,
MigSoft.
MigSoft.
I don't think so...
Let us know about your experiments.
- MigSoft
Hello,
These are the results:
2010.04.04 19:51:26 Windows 7 6.1.7600
Harbour 2.1.0dev (Rev. 14264) MinGW GNU C 4.4.1 (32-bit) x86
THREADS: 0
N_LOOPS: 1000000
[ T000: empty loop overhead ]...................................0.05
[ T001: x := L_C ]..............................................0.05
[ T002: x := L_N ]..............................................0.05
[ T003: x := L_D ]..............................................0.05
[ T004: x := S_C ]..............................................0.05
[ T005: x := S_N ]..............................................0.06
[ T006: x := S_D ]..............................................0.06
[ T007: x := M->M_C ]...........................................0.05
[ T008: x := M->M_N ]...........................................0.06
[ T009: x := M->M_D ]...........................................0.06
[ T010: x := M->P_C ]...........................................0.06
[ T011: x := M->P_N ]...........................................0.05
[ T012: x := M->P_D ]...........................................0.06
[ T013: x := F_C ]..............................................0.14
[ T014: x := F_N ]..............................................0.20
[ T015: x := F_D ]..............................................0.11
[ T016: x := o:Args ]...........................................0.11
[ T017: x := o[2] ].............................................0.11
[ T018: round( i / 1000, 2 ) ]..................................0.25
[ T019: str( i / 1000 ) ].......................................0.87
[ T020: val( s ) ]..............................................0.22
[ T021: val( a [ i % 16 + 1 ] ) ]...............................0.39
[ T022: dtos( d - i % 10000 ) ].................................0.27
[ T023: eval( { || i % 16 } ) ].................................0.28
[ T024: eval( bc := { || i % 16 } ) ]...........................0.14
[ T025: eval( { |x| x % 16 }, i ) ].............................0.19
[ T026: eval( bc := { |x| x % 16 }, i ) ].......................0.20
[ T027: eval( { |x| f1( x ) }, i ) ]............................0.30
[ T028: eval( bc := { |x| f1( x ) }, i ) ]......................0.27
[ T029: eval( bc := &("{ |x| f1( x ) }"), i ) ].................0.27
[ T030: x := &( "f1(" + str(i) + ")" ) ]........................1.93
[ T031: bc := &( "{|x|f1(x)}" ), eval( bc, i ) ]................2.07
[ T032: x := valtype( x ) + valtype( i ) ].....................0.30
[ T033: x := strzero( i % 100, 2 ) $ a[ i % 16 + 1 ] ]..........0.84
[ T034: x := a[ i % 16 + 1 ] == s ].............................0.30
[ T035: x := a[ i % 16 + 1 ] = s ]..............................0.30
[ T036: x := a[ i % 16 + 1 ] >= s ].............................0.30
[ T037: x := a[ i % 16 + 1 ] <= s ].............................0.28
[ T038: x := a[ i % 16 + 1 ] < s ]..............................0.28
[ T039: x := a[ i % 16 + 1 ] > s ]..............................0.31
[ T040: ascan( a, i % 16 ) ]....................................0.22
[ T041: ascan( a, { |x| x == i % 16 } ) ].......................1.97
[ T042: iif( i%1000==0, a:={}, ) , aadd(a,{i,1,.T.,s,s2,a2 ]....0.66
[ T043: x := a ]................................................0.06
[ T044: x := {} ]...............................................0.08
[ T045: f0() ]..................................................0.08
[ T046: f1( i ) ]...............................................0.11
[ T047: f2( c[1...8] ) ]........................................0.09
[ T048: f2( c[1...40000] ) ]....................................0.11
[ T049: f2( @c[1...40000] ) ]...................................0.09
[ T050: f2( @c[1...40000] ), c2 := c ]..........................0.12
[ T051: f3( a, a2, s, i, s2, bc, i, n, x ) ]....................0.41
[ T052: f2( a ) ]...............................................0.11
[ T053: x := f4() ].............................................0.36
[ T054: x := f5() ].............................................0.17
[ T055: x := space(16) ]........................................0.14
[ T056: f_prv( c ) ]............................................0.28
[ total application time: ]....................................19.56
[ total real time: ]...........................................19.99
2010.04.04 19:25:10 Windows 7 6.1.7600
Harbour 2.1.0dev (Rev. 14234) MinGW GNU C 4.4.4 (64-bit) x86-64
THREADS: 0
N_LOOPS: 1000000
[ T000: empty loop overhead ]...................................0.06
[ T001: x := L_C ]..............................................0.00
[ T002: x := L_N ]..............................................0.00
[ T003: x := L_D ]..............................................0.00
[ T004: x := S_C ]..............................................0.00
[ T005: x := S_N ]..............................................0.02
[ T006: x := S_D ]..............................................0.00
[ T007: x := M->M_C ]...........................................0.02
[ T008: x := M->M_N ]...........................................0.00
[ T009: x := M->M_D ]...........................................0.00
[ T010: x := M->P_C ]...........................................0.00
[ T011: x := M->P_N ]...........................................0.02
[ T012: x := M->P_D ]...........................................0.00
[ T013: x := F_C ]..............................................0.11
[ T014: x := F_N ]..............................................0.11
[ T015: x := F_D ]..............................................0.05
[ T016: x := o:Args ]...........................................0.08
[ T017: x := o[2] ].............................................0.06
[ T018: round( i / 1000, 2 ) ]..................................0.11
[ T019: str( i / 1000 ) ].......................................0.27
[ T020: val( s ) ]..............................................0.12
[ T021: val( a [ i % 16 + 1 ] ) ]...............................0.25
[ T022: dtos( d - i % 10000 ) ].................................0.20
[ T023: eval( { || i % 16 } ) ].................................0.20
[ T026: eval( bc := { |x| x % 16 }, i ) ].......................0.12
[ T027: eval( { |x| f1( x ) }, i ) ]............................0.22
[ T028: eval( bc := { |x| f1( x ) }, i ) ]......................0.20
[ T029: eval( bc := &("{ |x| f1( x ) }"), i ) ].................0.20
[ T030: x := &( "f1(" + str(i) + ")" ) ]........................1.64
[ T031: bc := &( "{|x|f1(x)}" ), eval( bc, i ) ]................2.06
[ T032: x := valtype( x ) + valtype( i ) ].....................0.22
[ T033: x := strzero( i % 100, 2 ) $ a[ i % 16 + 1 ] ]..........0.44
[ T034: x := a[ i % 16 + 1 ] == s ].............................0.16
[ T035: x := a[ i % 16 + 1 ] = s ]..............................0.17
[ T036: x := a[ i % 16 + 1 ] >= s ].............................0.16
[ T037: x := a[ i % 16 + 1 ] <= s ].............................0.17
[ T038: x := a[ i % 16 + 1 ] < s ]..............................0.16
[ T039: x := a[ i % 16 + 1 ] > s ]..............................0.14
[ T040: ascan( a, i % 16 ) ]....................................0.16
[ T041: ascan( a, { |x| x == i % 16 } ) ].......................1.53
[ T042: iif( i%1000==0, a:={}, ) , aadd(a,{i,1,.T.,s,s2,a2 ]....0.48
[ T043: x := a ]................................................0.00
[ T044: x := {} ]...............................................0.06
[ T045: f0() ]..................................................0.03
[ T046: f1( i ) ]...............................................0.08
[ T047: f2( c[1...8] ) ]........................................0.08
[ T048: f2( c[1...40000] ) ]....................................0.06
[ T049: f2( @c[1...40000] ) ]...................................0.08
[ T050: f2( @c[1...40000] ), c2 := c ]..........................0.09
[ T051: f3( a, a2, s, i, s2, bc, i, n, x ) ]....................0.25
[ T052: f2( a ) ]...............................................0.06
[ T053: x := f4() ].............................................0.28
[ T054: x := f5() ].............................................0.14
[ T055: x := space(16) ]........................................0.09
[ T056: f_prv( c ) ]............................................0.20
[ total application time: ]....................................15.18
[ total real time: ]............................................15.53
"Exe files" for your tests
THREADS: 0
N_LOOPS: 1000000
THREADS: 0
N_LOOPS: 1000000
- speedtst.zip
- (987.18 KiB) Downloaded 792 times
MigSoft.
MigSoft.
Nice. Thanks for sharing MigSoft.
- Czarny_Pijar
Had expected someone to double the speed? Real-life application will benefits even less, they depends mainly on the HDD throughput.MigSoft wrote:These are the results:
(32-bit [ total real time: ]...........................................19.99
(64-bit)[ total real time: ]............................................15.53
