HMG 3.0.28
HMG 3.0.28
- HMG 3.0.28 Changelog:
English:
- Fixed: IDE. OnHScroll event edit problems. Reported by Czarny_Pijar.
- Fixed: Problems with data-bound Grid code generated by IDE. Reported by Claudio Tedesco.
- Fixed: Data-bound grid problems when refreshing after an order change (\samples\grid.35). Reported by Ralph.
- Fixed: Problems with a report sample. Reported by Claudio Tedesco.
Español:
- Solucionado: IDE. Problemas de edición con el evento OnHScroll. Reportado por Czarny_Pijar.
- Solucionado: Problemas con data-bound Grid cuando el código es generado por el IDE. Reportado por Claudio Tedesco.
- Solucionado: Problemas al actualizar data-bound Grid después de cambiar el orden de la tabla (\samples\grid.35). Reportado por Ralph.
- Solucionado: Problemas ejemplo de report. Reportado por Claudio Tedesco.
Descarga/Download:site
Re: HMG 3.0.28
Thanks a lot master.
Vanguarda
Re: HMG 3.0.28
Post by Vanguarda »
Thanks master for this new release.
My best regards,
Re: HMG 3.0.28
Hello Roberto,
Thank you very much :D
swapan
Re: HMG 3.0.28
Post by swapan »
Thanks a lot.
And hope in any future release you'll incorporate the following:
http://hmgforum.com/viewtopic.php?f=5&t=1203&start=40
Thanks & Regards,
Swapan Das
http://www.swapandas.com/
Re: HMG 3.0.28
Thanks!
I wanto to submit an idea about grid and browse (I know browse is discontinued, but now, it has some advantages....).
When these controls are used in edit mode, special small window is opened. But hotkeys defined in window containing grid or browse are not processed.
I've tried to link calculator to F3 key, it works fine in other controls than grid...
Re: HMG 3.0.28
Thanks a lot Maestro
Best Regards
Re: HMG 3.0.28
mol wrote:Thanks!
It could be easily done, but, it could bring some side effects that should be carefully considered.
Added to my TODO list.
Re: HMG 3.0.28
swapan wrote:Thanks a lot.
It is already in my TODO list.
Algernon
Re: HMG 3.0.28
Post by Algernon »
Thanks a lot Roberto
It goes very fast, I started with 3.0.25,....26,....27,.... and now 28
Javier Suárez
La obra humana más bella es la de ser útil al prójimo. (Sófocles)
The most beautiful work of man is to be useful to others. (Sófocles)
