When browsing the hmg samples I noticed there is a difference in syntax between the 'basic report' demos and the 'advanced demos'.
Can someone explain the difference? Are these 2 different report engines?
Where can I find the syntax for the RPT file for the basic reports?
Thans - Richard
report generation
- HMG Founder
Re: report generation
Yes, they are different report engines.t57042 wrote:When browsing the hmg samples I noticed there is a difference in syntax between the 'basic report' demos and the 'advanced demos'.
Thans - Richard
The first is a superb work from Ciro Vargas Clemow, implemented trough the DO REPORT command.
This report generator is 'tabular format' (Clipper style) format.
It is very easy to use and powerful.
The second is 'band oriented' (FoxPro/Access style) and it is implemented via DEFINE REPORT command.
Both allow to define the reports in source code along the program or via an external file.
Both are documented in HMG reference (\doc\hmgdoc.htm) and in the samples (\samples\report*).
IDE allows to create and modify reports via a builder (wizard).
