Harbour MiniGUI 2.6.7
English:
- Fixed: Errors in documentation.
- Fixed: Problems with semi-oop preprocessor directives introduced
in 2.6.6. Reported by Marek and Grigory Filatov.
- Fixed: Problem with libhbmysql.a. Reported by Osvaldo Tambutti.
Español:
- Solucionado: Errores en la documentación.
- Solucionado: Problemas con las directivas de preprocesador (semi-oop)
introducidos en la versión 2.6.6. Reportado por Grigory Filatov.
- Solucionado: Problema con libhbmysql.a. Reportado por Osvaldo Tambutti.
Re: Harbour MiniGUI 2.6.7
Thanks a lot Roberto.
Roberto Lopez wrote:- Fixed: Problems with semi-oop preprocessor directives
Thanks and congratulations !
Although this update had been more painful, the result is perfect :D
Best Regards
Best Regards
Consistent handling of containers was in my head during years, but I've delayed because I knew that it could be a painful task :)
jas_sierra
DBs Used: DBF, Starting In MySQL
Post by jas_sierra »
Greetings, Mr. Roberto when reifere to errors in documentation that is exactly mean, commands or functions that do not work properly with the parameters set?, Thanks for your time.
rcain
Post by rcain »
Roberto,
I am having a great time, relearning Clipper coding....
I am using the IDE to create screens, and have found that I need to write very little code!
I have come across one problem. or an difference in the way two controls work.
I am setting the FIELD property on TEXTBOX and DATEPICKER at design time.
The sequence of steps is as follows:
Function Process_Family_Members()
Load Window frmFamily_member
frmFamily_member.Center
DBGOTO(Recno)
frmFamily_member.Activate
When the screen is displayed, all fields contain data from the record, except
DATEPICKER, it contains the current date, no matter what is in the record.
If however, I execute the method:
frmFamily_member.txtDate1.Refresh && DATEPICKER Field
or if I load the value with:
frmFamily_member.txtDate1.Value := PEOPLE->Date1
after the DBGOTO command, the correct data will be displayed in the DATEPICKER
field on the screen.
The TEXTBOX controls work without the REFRESH method!
The work around is simple, but just something I have to remember to do…
Thanks for all of your work,
Robin D. Cain :o
Hello Roberto!
Today (2.12.2008), I've installed my client my new application (compiled using hmg 2.6.7 and IDE 2.6.4)
On one screen user must fill some fields then press "SAVE" button for saving record into database.
Client has filled all fields, then using "tab" key set focus on "SAVE" button and (I don't know why....) pressed simultaneously ENTER on keyboard and left button on mouse.
And what happened?
Program saved two the same records into database - function under "SAVE" button has been executed two times!!! It's strange because there is "RELEASE WINDOW at the end of MySaveRecord function.
Tomorrow, I'll try to do it in my old application compiled with earlier version of hmg. I'll write about my observation...
P.S. Sorry for my poor English
Marek
Roberto,
Como siempre, gracias por la nueva version.
Un abrazo,
Luis Vasquez
I've compiled program using:
Harbour MiniGUI 2.0.031 (2007.06.26)
Harbour MiniGUI IDE 2.0 Build 2007.02.22
and have done test - press left mouse button on SAVE button and ENTER on keyboard - the same effect - two exactly the same records in database - function which save data was called two times and after that window was released.
How it is possible?
It is not big problem, but exists...
Marek
mol wrote:I've compiled program using:
How it is possible?
Hello Marek,
Try the following workaround with a busy flag as below:
 * MiniGUI Hello World Demo
 * (c) 2002-2004 Roberto Lopez <harbourminigui@gmail.com>
#include "minigui.ch"
Static lBusy := .F.
Procedure Main
	DEFINE WINDOW Form_1 ;
		WIDTH 400 ;
		HEIGHT 200 ;
		TITLE 'Hello World!' ;
		MAIN ;
		ON INIT OpenTables() ;
		ON RELEASE CloseTables()
		DEFINE BUTTON Button_1
			ROW	10
			COL	10
			CAPTION 'Save'
			ACTION Save()
		END BUTTON
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Procedure Save
if !lBusy
	lBusy := .T.
	append blank
	inkey(.2)
	lBusy := .F.
ThisWindow.Release
Procedure OpenTables()
	Use Test
	zap
	Go Top
Procedure CloseTables()
	Use
I hope that give you an idea.
