Ceiling() function with Macro
Hello All,
I found some problem with using CEILING() function with Macro. Interestingly I found it works, only if I call CEILING() function directly as a dummy function!!! ;)
   DEFINE WINDOW main at 0, 0 width 450 height 300  TITLE "Macro Test with CEILING() function!!!" MAIN
      DEFINE TEXTBOX Text_1
         ROW    50
         COL    80
         INPUTMASK "9999.999"
         FORMAT Nil
         NUMERIC .T.
      END TEXTBOX
      DEFINE BUTTON Button_1
         ROW    50
         COL    300
         ACTION test1()
         CAPTION "Gives Error!!!"
      END BUTTON
   Main.Text_1.value := 100.001
   Main.Center
   Main.Activate
function Test1()
   local x := "CEILING("+str(main.text_1.value)+")"
   // dummy
   //CEILING(1) // but runs fine when you clear the comments of this line before ceiling()!!!
   msgbox(str(&x))
   return nil
I have very little knowlege on macro. So, can you please help me to understand the behavior :)
Thanks in advance. :)
Re: Ceiling() function with Macro
Hi Sudip
REQUEST CEILING
Czarny_Pijar
Post by Czarny_Pijar »
Try other functions ( SIN, TAN ) - the result is the same.
I guess this is not macro related behaviour, this is the dynamic linking factor, where only the functions spotted in the code are included in the exe file. As esgici suggested, you have to explicity inform the linker, which functons haven't to be omitted.
Thanks lot Esgici, Czarny Pijar :)
It works :)
