I've never seen any other user of HMG, "feel uncomfortable" with the space displayed in the first column of a browse control or grid control.
Some time in this section, I proposed many suggestions to this control,.... this time I just want to know if there is any way or any tricks to avoid this behavior (I have experienced with HMG sources and I've had no luck).
And also avoid the dotted lines when you select an element of these controls, please take a look at the attached image.
Please I await your comments
Best Regards
Javier
Two wishes Grid control
- img_1.png (12.12 KiB) Viewed 3329 times
Re: Two wishes Grid control
I don't understand your problem Javier.
Could you please explain?
Hi Rathinagiri,
My "problem" is that I personally do not like the small space that is displayed in a Grid/Browse control (please take a look at the attached image) in the first column.
I probably made a mistake, I did not mention that the image attached in my first post of this thread is "how I wish" that these controls are displayed.
In the image (attached in the first post of this thread) does not appreciate the small space in the first column, the dotted lines to select an item not displayed either.
And about my comment:
P.S. I know it uses the Windows API, but... almost always a solution/trick for almost everything.
Thanks for "listening".
Best Regards
Javier
I believe I have not "seen" any HMG developer, expressing "not feel comfortable" with a couple of details that I mentioned, and I wonder if they've already solved by doing some "trick" or that no "matter"?.I've never seen any other user of HMG, "feel uncomfortable "...,
Best Regards
Javier
- img_1.png (12.81 KiB) Viewed 3290 times
