Which DBF viewer?
- Czarny_Pijar
Which DBF viewer?
Please give me the info, which program fits yours needs as a viewer of DBF file.
I'm used to NortonCommander & DBView combo from the old DOS, and I'm looking for something similar for Windows:
- capaple to associate with DBF file,
- lightweight,
- quick,
- simple
- informative,
- safe = without edit/append/delete/restructure/create/zap capabilities,
- freeware if possible.
- lightweight,
- quick,
- simple
- informative,
Re: Which DBF viewer?
DBFNavigator is a Windows utility for viewing and editing DBF files. (No index)
http://www.alxsoft.narod.ru/ENG/dbfnav.htm
Opportunities of the program:
- versions from dBase up to Visual FoxPro are supported;
- may read memo fields dBase and FoxPro formats;
- are supported OEM and ANSI codings;
- sort;
- filter;
- search;
- a seal.
The program does not use external drivers for access to databases (for example ODBC, BDE, MS Jet) additional libraries (dll, ocx).
It's free !
Saludos !
Walter
- sort;
- filter;
- search;
- a seal.
It's free !
Saludos !
Walter
I would re-compile HMG-DBU and provide here ASAP.
Very good news Rathi
We really need it.
We really need it.
Hi Czarny_PijarCzarny_Pijar wrote:Please give me the info, which program fits yours needs as a viewer of DBF file.
Did you seen DBA ?
I used DBA. It's an excellent utility
For me the most powerfull is Prometheus 2000, is free.Czarny_Pijar wrote:Please give me the info, which program fits yours needs as a viewer of DBF file.
- lightweight,
- quick,
- simple
- informative,
Saludos, Fernando Chirico.
- mustafa
Hello
I've created my own Dbf View of our HMG
I Dbf Files, amended and Structural modifications.
If you want to try:
viewtopic.php?f=15&t=1244
greetings
Hola
Yo me he fabricado mi propio View de Dbf con nuestro HMG
Creo Ficheros Dbf , Modifico y Modifico Estructuras.
Si quieres probarlo :
un saludo
If you want to try:
greetings
Hola
un saludo
- Czarny_Pijar
Yes, I use this utility, is OK. The only one drawback I see in the version 3.12.1 - the name of the database is displayed in 8.3 manner...esgici wrote:Did you seen DBA ?
Example: my_database.dbf ==>> my_data~.dbf
Prometheus is very popular name in the internet, so I cannot spot the proper sitefchirico wrote:For me the most powerfull is Prometheus 2000, is free.
This is for fitting file name(s) in browse header, when you open multiple table at a time.Czarny_Pijar wrote:Yes, I use this utility, is OK. The only one drawback I see in the version 3.12.1 - the name of the database is displayed in 8.3 manner...esgici wrote:Did you seen DBA ?
You can see full file name (including its path) of active table in status bar.
