HMG 2.6.6
HMG 2.6.6
English:
- Fixed: Error in documentation. Reported by Grigory Filatov.
- Fixed: Another problem in print preview introduced in 2.6.2.
- Fixed: Semi-oop syntax for containers. Tab, ToolBar and SplitBox
child controls can be (optionally) referred as follows:
ToolBar Buttons:
Window.ToolBar.Button
Tab child controls:
Window.Tab(nPage).Control
SplitBox child controls ('SplitBox' name is automatically assigned):
Window.SplitBox.Control
When a ToolBar is in a SplitBox, the syntax is as follows:
Window.SplitBox.ToolBar.Button
Samples: \hmg\samples\containers.
Español:
- Solucionado: Error en la documentación. Reportado por Grigory Filatov.
- Solucionado: Otro problema en la vista previa de impresión introducido
en la versión 2.6.2. Reportado por Grigory Filatov.
- Solucionado: Sintaxis semi-oop para contenedores. Los controles
pertenecientes a un Tab, SplitBox o ToolBar pueden ser referidos
(opcionalmente) según se indica a continuación:
Botones de ToolBar:
Controles en Tab:
Controles en SplitBox (El nombre 'SplitBox' es asignado
automáticamente):
Cuando un ToolBar está en un SplitBox, la sintaxis es:
Ejemplos: \hmg\samples\containers.
Re: HMG 2.6.6
Nice enhancement. Thank you Roberto.
Re: HMG 2.6.6
I have reached an Error in situation like this:
I have defined window:
Define Window OknoUstawienia
and later, if I want to read "row" value:
xpos := OknoUstawienia.row
I get error:
Error BASE/1003 Zmienna nie istnieje: _OKNOUSTAWIENIA_ROW
^^^^^^^variable does not exist.... ^^^^^^^^^^^^^
Called from GETCONTROLTYPE(871)
Called from GETPROPERTY(6864)
It worked up to ver. hmg 2.6.4
I tried GetProperty:
GetProperty("OknoUstawienia","ROW")
and it works properly...
What's going on?
Best regards, Marek "MOL", Poland
Re: HMG 2.6.6
mol wrote:I have reached an Error in situation like this:
I get error:
What's going on?
Hi Marek,
There are a semi-oop changes introduced since hmg 2.6.5.
Tip: to add a brackets for your semi-oop declaration OknoUstawienia.row,
f.e. ( OknoUstawienia.row )
But I don't confirm a such problem for the following sample:
* MiniGUI This Demo
* (c) 2003 Roberto Lopez
#include "minigui.ch"
	DEFINE WINDOW Form_1 ;
		WIDTH 400 ;
		HEIGHT 200 ;
		TITLE 'This Demo' ;
		MAIN ;
		ON INIT This.Title := 'New Title (From This)'
		@ 10,10 BUTTON Button_1 ;
			CAPTION 'Hi!!!' ;
			ACTION ThisTest() ;
			TOOLTIP 'Test Tip'
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
Procedure ThisTest()
	ThisWindow.Row := 10
	ThisWindow.Col := 10
	MsgInfo ( str(Form_1.Row)+str(Form_1.Col) , This.Name )  // this line without error
	MsgInfo ( This.Caption )
	This.Hide
	MsgInfo (This.Name)
	MsgInfo ( This.ToolTip )
	This.Show
Re: HMG 2.6.6
Is this problem will be solved or we will have to modify all the programs?
Luis Vásquez.
Re: HMG 2.6.6
I get error:
What's going on?
Mol, Grigory, Luis:
The changes made in 2.6.5 should be backwards compatible, if not, it is an error and I'll try to fix it.
Please send a complete sample showing the problem, since, the row property for windows is working for me, so, I can't confirm (or try to fix) a bug.
Thanks.
Re: HMG 2.6.6
Roberto Lopez wrote: Mol, Grigory, Luis:
Thanks.
Roberto,
Try the following sample at the folder samples\containers\toolbar:
 * Copyright 2002 Roberto Lopez <harbourminigui@gmail.com>
	DEFINE WINDOW Form_0 ;
		WIDTH 640 HEIGHT 480 ;
		TITLE 'MiniGUI ToolBar Demo' ;
		ICON 'DEMO.ICO' ;
		MAIN ;
		FONT 'Arial' SIZE 10
		ON KEY F2 ACTION MsgInfo('F2 (Main)')
		DEFINE STATUSBAR
			STATUSITEM 'HMG Power Ready!'
		END STATUSBAR
		DEFINE MAIN MENU
			POPUP '&File'
				ITEM '&Disable ToolBar Button'	ACTION Form_0.Toolbar_1.Button_1.Enabled := .F.
				ITEM '&Enable ToolBar Button'	ACTION Form_0.Toolbar_1.Button_1.Enabled :=  .T.
				SEPARATOR
				ITEM 'Get ToolBar Button Caption' ACTION MsgInfo( Form_0.Toolbar_1.Button_1.Caption)
				SEPARATOR
				ITEM 'Set ToolBar Button Caption' ACTION SetProperty ( 'Form_0' , 'ToolBar_1' , 'Button_1' , 'Caption' , 'New New' )
				SEPARATOR
				ITEM '&Exit'			ACTION Form_0.Release
			END POPUP
			POPUP '&Help'
				ITEM '&About'		ACTION MsgInfo ("MiniGUI ToolBar demo")
			END POPUP
		END MENU
		DEFINE TOOLBAR ToolBar_1 BUTTONSIZE 85,85 FLAT BORDER
			BUTTON Button_1 ;
			CAPTION '&More ToolBars...' ;
			PICTURE 'button1.bmp' ;
			ACTION Modal_Click()  TOOLTIP 'ONE'
			BUTTON Button_2 ;
			CAPTION '&Button 2' ;
			PICTURE 'button2.bmp' ;
			ACTION MsgInfo('Click! 2')  TOOLTIP 'TWO'
			BUTTON Button_3 ;
			CAPTION 'Button &3' ;
			PICTURE 'button3.bmp' ;
			ACTION MsgInfo('Click! 3')  TOOLTIP 'THREE'
		END TOOLBAR
	Form_0.Toolbar_1.Col := Form_0.Width - Form_0.Toolbar_1.Width - 15  // this problem string
	CENTER WINDOW Form_0
	ACTIVATE WINDOW Form_0
Procedure Modal_CLick
	DEFINE WINDOW Form_2 ;
		WIDTH 400 HEIGHT 300 ;
		TITLE 'ToolBar Test'  ;
		MODAL NOSIZE
		ON KEY F2 ACTION MsgInfo('F2 (Child)')
		ON KEY F10 ACTION MsgInfo('F10 (Child)')
		DEFINE TOOLBAR ToolBar_1 FLAT BUTTONSIZE 100,30 BOTTOM RIGHTTEXT
			BUTTON Button_1 ;
			CAPTION '&Undo' ;
			PICTURE 'button4.bmp' ;
			ACTION MsgInfo('UnDo Click!')
			BUTTON Button_2 ;
			CAPTION '&Save' ;
			PICTURE 'button5.bmp' ;
			ACTION MsgInfo('Save Click!')
			BUTTON Button_3 ;
			CAPTION '&Close' ;
			PICTURE 'button6.bmp' ;
			ACTION Form_2.Release
		END TOOLBAR
	Form_2.Center
	Form_2.Activate
and you have got this error message:
Harbour MiniGui Errorlog File
Date:10/01/08 Time: 21:22:45
Error BASE/1003 Variable does not exist: _FORM_0_WIDTH
Called from MAIN(63)
But the following sample works properly (after adding parentheses):
		ICON 'DEMO.ICO' ;
		MAIN ;
		DEFINE STATUSBAR
		END STATUSBAR
		DEFINE MAIN MENU
			POPUP '&File'
				SEPARATOR
				SEPARATOR
				SEPARATOR
			END POPUP
			POPUP '&Help'
			END POPUP
		END MENU
			BUTTON Button_1 ;
			BUTTON Button_2 ;
			BUTTON Button_3 ;
		END TOOLBAR
	Form_0.Toolbar_1.Col := Form_0.Width - ( Form_0.Toolbar_1.Width ) - 15
		MODAL NOSIZE
			BUTTON Button_1 ;
			CAPTION '&Undo' ;
			BUTTON Button_2 ;
			CAPTION '&Save' ;
			BUTTON Button_3 ;
			CAPTION '&Close' ;
		END TOOLBAR
	Form_2.Center
	Form_2.Activate
Re: HMG 2.6.6
Grigory:
The expression: "Form_0.Toolbar_1.Col" has no sense, since ToolBar control has not a 'Col' property.
Re: HMG 2.6.6
Grigory:
If in the same program, at the same place you put the following code:
	nTest := Form_0.Row
	MsgInfo ( Str(nTest) )
It is working, retrieving correctly the row property value.
This is because I've requested to MOL a complete sample showing the problem and (if it exists) fix it.
Re: HMG 2.6.6
Roberto Lopez wrote: If in the same program, at the same place you put the following code:
	nTest := Form_0.Row
Finally:
Again, in the same sample, at the same place, if you paste the following:
	Form_0.row := form_0.row - 50
You'll obtain a compile (not runtime) error, but it has nothing to do with 2.6.5 changes.
You could test with 2.0.032 and obtain the same syntax error, that you can avoid using parenthesis.
