Hola Gente
Tengo un formulario donde tengo 2 textbox numericos y cuando ejecuto un boton
para mostrar el resultado en un label no aparece nada, en caso contrario si en un texbox.
Estare haciendo algo mal?
Adjunto el ejemplo.
declare window ventana3
Function ventana3_button_1_action
wcal := ventana3.text_3.value + ventana3.text_4.value
ventana3.text_5.value := wcal
ventana3.label_5.value := wcal
* HMG-IDE Form Designer Generated Code
* (c) Roberto Lopez - http://harbourminigui.googlepages.com
DEFINE WINDOW TEMPLATE AT 163 , 316 WIDTH 665 HEIGHT 350 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "ventana 3" ICON NIL CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR Nil NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
DEFINE LABEL Label_1
ROW 10
COL 280
WIDTH 120
HEIGHT 24
VALUE "VENTANA 3"
FONTNAME "Times"
FONTSIZE 14
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
DEFINE TEXTBOX Text_1
ROW 70
COL 180
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
BACKCOLOR NIL
FONTCOLOR NIL
INPUTMASK Nil
FORMAT Nil
VALUE ""
END TEXTBOX
DEFINE TEXTBOX Text_2
ROW 110
COL 180
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
BACKCOLOR NIL
FONTCOLOR NIL
INPUTMASK "99/99/9999"
FORMAT Nil
DATE .T.
VALUE Nil
END TEXTBOX
DEFINE TEXTBOX Text_3
ROW 150
COL 180
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
BACKCOLOR NIL
FONTCOLOR NIL
INPUTMASK "999.99"
FORMAT Nil
NUMERIC .T.
VALUE Nil
END TEXTBOX
DEFINE LABEL Label_2
ROW 70
COL 90
WIDTH 70
HEIGHT 20
VALUE "caracter"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
DEFINE LABEL Label_3
ROW 110
COL 90
WIDTH 70
HEIGHT 20
VALUE "fecha"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
DEFINE LABEL Label_4
ROW 150
COL 90
WIDTH 70
HEIGHT 20
VALUE "numerico"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
DEFINE TEXTBOX Text_4
ROW 150
COL 330
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
BACKCOLOR NIL
FONTCOLOR NIL
INPUTMASK "999.99"
FORMAT Nil
NUMERIC .T.
VALUE Nil
END TEXTBOX
DEFINE BUTTON Button_1
ROW 190
COL 340
WIDTH 100
HEIGHT 28
ACTION ventana3_button_1_action()
CAPTION "Calcular cuenta"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
HELPID Nil
FLAT .F.
TABSTOP .T.
VISIBLE .T.
TRANSPARENT .F.
MULTILINE .F.
PICTURE Nil
PICTALIGNMENT TOP
END BUTTON
DEFINE TEXTBOX Text_5
ROW 190
COL 460
WIDTH 120
HEIGHT 24
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
ONCHANGE Nil
ONGOTFOCUS Nil
ONLOSTFOCUS Nil
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
ONENTER Nil
HELPID Nil
TABSTOP .T.
VISIBLE .T.
READONLY .F.
RIGHTALIGN .F.
BACKCOLOR NIL
FONTCOLOR NIL
INPUTMASK "9999.99"
FORMAT Nil
NUMERIC .T.
VALUE Nil
END TEXTBOX
DEFINE LABEL Label_5
ROW 150
COL 480
WIDTH 120
HEIGHT 24
VALUE "Label_5"
FONTNAME "Arial"
FONTSIZE 9
TOOLTIP ""
FONTBOLD .F.
FONTITALIC .F.
FONTUNDERLINE .F.
FONTSTRIKEOUT .F.
HELPID Nil
VISIBLE .T.
TRANSPARENT .F.
ACTION Nil
AUTOSIZE .F.
BACKCOLOR NIL
FONTCOLOR NIL
END LABEL
Consulta por control Label
claudiotedesco
- form.jpg (52.23 KiB) Viewed 3161 times
Re: Consulta por control Label
Hi my friend,
Please try convert the value of text box to character.
Per example:
I hope that help you.
My best regards,
Per example:
Main.Label_1.Value := Alltrim(Str(Main.Text_2.Value))My best regards,
- Czarny_Pijar
Hi. Take a look here:
The complete example zipped below.
Function button_1_action()
str1:= Main.text_1.value
str2:= Main.text_2.value
wcal_1 := ALLTRIM(str1 + str2)
Main.text_3.value := wcal_1
Main.label_1.value := wcal_1
wcal_2 := ALLTRIM( str( val(str1) + val(str2) ))
Main.text_4.value := wcal_2
Main.label_2.value := wcal_2
Return Nil- Attachments
- hmgforum.zip
- Working example for string manipulation
- (1.39 KiB) Downloaded 295 times
claudiotedesco
Hola
Muchas gracias lo voy a probar
les agradezco su ayuda
Claudio
Claudio
