This is a small bug fixed version of HFCL.
You can download the latest version from here.
site
HFCL 0.95a (2010-03-18)
Re: HFCL 0.95a (2010-03-18)
Thanks Rathi for this new release.
My best regards,
My best regards,
Español
Hola Rathi
A ocurrido un error, al querer resetear el formulario, mira el log
English
Hi Rathi
An error occurred, wanting to reset the form, see the log
Harbour MiniGui Errorlog File
Date:03/18/10 Time: 21:08:04
Error BASE/1132 Bound error: array access
Called from RESETPRINTGRIDFORM(2438)
Called from (b)_GRIDPRINT(748)
Called from _DOCONTROLEVENTPROCEDURE(4933)
Called from EVENTS(1380)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4597)
Called from DOMETHOD(7373)
Called from _GRIDPRINT(796)
Called from DOPRINT(148)
Called from (b)MAIN(134)
Called from _ACTIVATEWINDOW(4575)
Called from MAIN(142)
Greetings
Hola Rathi
English
Hi Rathi
Greetings
Thanks for reporting. I will do ASAP.
I had fixed the bug and uploaded the bug fixed edition. Kindly re-download the file and test the same.
Thanks a lot Rathi
Is there any way to use Combo Search Box with Grid? As far I remember, once Roberto gave a hint for this, but, I can't find it now
Yes we can do that. There are two ways to do that.
1. By processing the when/valid block by ourselves.
2. By modifying HMG sourcecode a little.
