Is this a grid bug?
Kana
Is this a grid bug?
Post by Kana »
In the example below I can not get value for the last cell in the grid
If I insert a new item and when I try the updates the same item, I receive the following message:
1. - 1111
- 3333
2. - 1111
- 3333
Why
mainform.sqlgrid.cell (mainform.sqlgrid.value, 3) and mainform.sqlgrid.item (mainform.sqlgrid.value) [3]
do not give a value?
#include 'minigui.ch'
#define adOpenForwardOnly 0
#define adOpenKeyset      1
#define adOpenDynamic     2
#define adOpenStatic      3
#define adLockReadOnly        1
#define adLockPessimistic     2
#define adLockOptimistic      3
#define adLockBatchOptimistic 4
#define adUseNone   1
#define adUseServer 2
#define adUseClient 3
static oCreateCon, oRecordSet
procedure main
  OpenMdb()
	define window mainform;
		at 0,0 width 400 height 400 title 'Demo SQL ADO (Access)';
		Main;
		on release  ( oCreateCon:Close() );
		on init     ( fill_grid(1) );
		font 'ms sans serif' size 8
    on key control+down of mainform action griditem(1)
    on key delete       of mainform action griditem(3)
		define grid sqlgrid
			row 10
			col 10
			width 362
			height 320
			headers {'id','firstname', 'lastname'}
			widths { 55, 150, 150}
			on change 	mainform.statusbar.item(1) := "Slog: "+ltrim(str(mainform.sqlgrid.value))+" od "+alltrim(str(mainform.sqlgrid.itemcount))
			allowedit .t.
			inplaceedit {}
			columncontrols	{ ;
					{'TEXTBOX','NUMERIC',repl('9',10)} , ;
					{'TEXTBOX','CHARACTER'}, ;
					{'TEXTBOX','CHARACTER'} ;
			columnvalid     { ;
					{ || if( Empty ( This.CellValue ), .f. ,  ) } , ;
					{ || if( Empty ( This.CellValue ), .f. , griditem(2)) } ;
		end grid
		define statusbar
			statusitem "Slog: -"
			date
		end statusbar
	end window
	mainform.center
	activate window mainform
return
procedure fill_grid(n)
	local i := 1
	mainform.sqlgrid.Deleteallitems
	oRecordSet:Open("Select * from users order by id",oCreateCon,adOpenKeyset,adLockPessimistic)
	if oRecordSet == NIL
	  msgstop('connection error')
		for i= 1 to oRecordSet:RecordCount()
			mainform.sqlgrid.additem( {oRecordSet:Fields("ID"):Value, oRecordSet:Fields("Firstname"):Value, oRecordSet:Fields( "Lastname" ):Value})
			oRecordSet:MoveNext()
	  next
		mainform.sqlgrid.value:=n
	end
  oRecordSet:close()
	mainform.sqlgrid.setfocus
return
procedure griditem(n)
	local Cad := ""
	do case
	case n == 1
	  record_fill(n)
	case n == 2
		msginfo("1. -"+mainform.sqlgrid.cell(mainform.sqlgrid.value,2)+chr(13)+;
						"   -"+mainform.sqlgrid.cell(mainform.sqlgrid.value,3)+chr(13)+;
						"   -"+mainform.sqlgrid.item(mainform.sqlgrid.value)[3]+chr(13)+;
						"   -"+This.CellValue)
		record_fill(n)
	case n == 3
		Cad := "DELETE FROM users WHERE id="+str(mainform.sqlgrid.cell(mainform.sqlgrid.value,1))
		if msgyesno('Delete record?'+hb_osnewline()+mainform.sqlgrid.cell(mainform.sqlgrid.value,2),'Yes')
			oRecordSet:Open(Cad,oCreateCon,adOpenKeyset,adLockPessimistic)
				msgstop('delete error')
				n := mainform.sqlgrid.value
				mainform.sqlgrid.deleteitem( n )
				mainform.sqlgrid.value := iif(n > 1, n-1, 1)
				mainform.statusbar.item(1) := "Slog "+;
			end
		  //oRecordSet:close()
		end
	endcase
return
procedure record_fill(n)
	local cad := ""
	if n = 1
		Cad := "INSERT INTO users (firstname, lastname) VALUES (space(10), space(10))"
		msginfo("2. -"+mainform.sqlgrid.cell(mainform.sqlgrid.value,2)+chr(13)+;
		Cad := "UPDATE users SET firstname='"+mainform.sqlgrid.cell(mainform.sqlgrid.value,2)+;
																 "', lastname='"+mainform.sqlgrid.cell(mainform.sqlgrid.value,3)+;	//"', lastname='"+This.CellValue+;
																 "' WHERE id="+str(mainform.sqlgrid.cell(mainform.sqlgrid.value,1))
	end
		msgstop('update error')
	end
	if n == 1
		fill_grid(mainform.sqlgrid.itemcount+1)
		fill_grid(mainform.sqlgrid.value)
	end
	mainform.statusbar.item(1) := "Slog "+ltrim(str(mainform.sqlgrid.value))+" od "+alltrim(str(mainform.sqlgrid.itemcount))
return
procedure OpenMdb()
  Local oCreateCatalog
  if !file('demo.mdb')
    oCreateCatalog=CreateObject("ADOX.Catalog")
    oCreateCatalog:Create("Provider=Microsoft.Jet.OLEDB.4.0;Data Source=demo.mdb")
    oCreateCon:=CreateObject("ADODB.Connection")
    oCreateCon:Open("Provider=Microsoft.Jet.OLEDB.4.0;Data Source=demo.mdb")
    oCreateCon:Execute( "CREATE TABLE users ([id] autoincrement, [FirstName] char(10), [LastName] char(10))" )
    oCreateCon:Execute( "INSERT INTO users (FirstName, LastName) VALUES ('James', 'Bond')"  )
    oCreateCon:Execute( "INSERT INTO users (FirstName, LastName) VALUES ('Lara', 'Kroft')"  )
    oCreateCon:Execute( "INSERT INTO users (FirstName, LastName) VALUES ('Super', 'Man')"  )
    oCreateCon:Execute( "INSERT INTO users (FirstName, LastName) VALUES ('Lat'  , 'šđčćž')"  )
    oRecordSet:=CreateObject("ADODB.Recordset")
  end
return nil
Re: Is this a grid bug?
Kana wrote:In the example below I can not get value for the last cell in the grid
1. - 1111
- 3333
2. - 1111
- 3333
Why
#define adUseNone   1
procedure main
  OpenMdb()
		Main;
		define grid sqlgrid
			row 10
			col 10
			width 362
			height 320
			allowedit .t.
			inplaceedit {}
			columncontrols	{ ;
			columnvalid     { ;
		end grid
		define statusbar
			date
		end statusbar
	end window
	mainform.center
return
	local i := 1
	  next
	end
  oRecordSet:close()
return
	local Cad := ""
	do case
	case n == 1
	  record_fill(n)
	case n == 2
		record_fill(n)
	case n == 3
			end
		end
	endcase
return
	local cad := ""
	if n = 1
	end
	end
	if n == 1
	end
return
procedure OpenMdb()
  end
return nil
Could you be so kind to post the complete including the file(s) needed to test it.
TIA.
Kana
Post by Kana »
Roberto Lopez wrote: Could you be so kind to post the complete including the file(s) needed to test it.
TIA.
Hi, Roberto
This is all code, you need it with a text editor save the file for example demoado.prg and translate the call .. \ .. \ build.bat%
TIA.
Hi, Roberto
And the data file that you use to fill the grid?
Kana
Post by Kana »
TIA.
Hi, Roberto
OOPS! :)
Sorry, I've not seen that.
I'll take a look at it ASAP.
Thanks for the report.
PS: For future reports, please, try to create a smaller, simpler sample showing the problem.
Since to find what is exactly wrong with your code, could take to me a lot of hours, I've decided to do a small modification to test 'cel' property (the demo is attached).
As you'll see (using the new menu option) you can retrieve cell property for any row and col and it is working perfectly.
If you are not able to solve the problem and still thinking that it is a 'cell' property problem, please, create a simple, sample showing the cell property malfunction and post it here.
TIA.
GRID.RAR
(580.8 KiB) Downloaded 469 times
Kana
Post by Kana »
I removed my procedure clausule valid and entered your code from the menu
File-> 'Get Cell'
I'm interested in the following:
After the start the demo, when I press:
1. CTRL + down
2. ENTER x 2
3. 1111
4. ENTER
5. 3333
6. Enter Row 5
7. Enter Col. 3
Msg info that is " ' not '3333"
I hope that I managed to explain what interested me.
Why can not I read the value of LAST cells in the valid clausule except This.CellValue?
Is_it_bug.ZIP
(698.27 KiB) Downloaded 418 times
Kana wrote:I removed my procedure clausule valid and entered your code from the menu
File-> 'Get Cell'
1. CTRL + down
2. ENTER x 2
3. 1111
4. ENTER
5. 3333
6. Enter Row 5
7. Enter Col. 3
Because, you are asking about cell content inside the valid procedure, so, you are still editing, so, the new value was not accepted yet, so, this new value is not available for 'cell' property yet, so, this new value is available in 'This.CellValue' only, so, this is not a bug :)
When you finish the 'valid' procedure returning .t., the new value will be accepted and available for the 'cell' property.
Kana
Post by Kana »
Roberto Lopez wrote: Because, you are asking about cell content inside the valid procedure, so, you are still editing, so, the new value was not accepted yet, so, this new value is not available for 'cell' property yet, so, this new value is available in This.CellValue property only, so, this is not a bug :)
Thanks Roberto,
I have to change the logic and code in some places as:
"UPDATE users SET firstname = '" + mainform.sqlgrid.cell (mainform.sqlgrid.value, 2) +;
" ', Lastname ='" + mainform.sqlgrid.cell (mainform.sqlgrid.value, 3) +; //"', lastname = ' "+ + This.CellValue;
" 'WHERE id =" + str (mainform.sqlgrid.cell (mainform.sqlgrid.value, 1))
