Harbour MiniGUI 2.6.5
English:
- Fixed: Problem in print preview introduced in 2.6.2.
- Updated: Harbour compiler updated to version 1.01.
- Modified: Documentation.
Español:
- Solucionado: Problema en la vista previa de impresión introducido
en la versión 2.6.2.
- Actualizado: Harbour a la versión 1.01.
- Modificado: Documentación.
Re: Harbour MiniGUI 2.6.5
Hi Roberto
Many thanks in advance :)
Modified : Documentation
Reference.txt became .htmls :shock:
Best Regards
esgici wrote:Hi Roberto
Best Regards
Well... when I've reviewed the docs because your suggestions, I've discovered that were about 130 properties not documented at all!!!!
(no events and only some methods).
Besides that, there is a lot of problems with documentation consistency, so I've decided to start the painful task of document (at least briefly) all the library.
This will take a LOT of time... but... it must be done.
Roberto Lopez wrote:Well... when I've reviewed the docs because your suggestions, I've discovered that were about 130 properties not documented at all!!!!
Hi Roberto,
Take a look for this issue in doc\functions.html:
CallDll32()
Function: Opens the system color selection dialog and return selected color.
CallDll32 ( <cFunctionName> , <cDllName> , ... <parameters> ... ) --> xReturnValue
and also for a wrong action of MULTIPLY hotkey in Preview windows: :(
ON KEY MULTIPLY ACTION ( If ( _HMG_PRINTER_PPNAV.b5.value == .T. , _HMG_PRINTER_PPNAV.b5.value := .F. , _HMG_PRINTER_PPNAV.b5.value := .T. ) , _HMG_PRINTER_Zoom() )
Hi Roberto,
CallDll32()
Thanks for both reports. I'll fix them ASAP.
Likewise, in doc\properties.html
fontbold, italic, underline & strikeout all describes about fontsize only. In the case of fontstrikeout the variable is nFontstrikeout instead of lFontStrikeout. Errors are shown bold.
Fontbold
Set / Gets gui object's font size.
<ParentWindowName>.<ControlName>.FontBold := lFontBold
<ParentWindowName>.<ControlName>.FontBold --> lFontBold
Fontitalic
<ParentWindowName>.<ControlName>.FontItalic := lFontItalic
<ParentWindowName>.<ControlName>.FontItalic --> lFontItalic
Fontunderline
<ParentWindowName>.<ControlName>.FontUnderline := lFontUnderline
<ParentWindowName>.<ControlName>.FontUnderline --> lFontUnderline
Fontstrikeout
<ParentWindowName>.<ControlName>.FontStrikeOut := nFontStrikeOut
<ParentWindowName>.<ControlName>.FontStrikeOut --> nFontStrikeOut
rathinagiri wrote:Likewise, in doc\properties.html
Fontbold
Fontitalic
Fontunderline
Fontstrikeout
Thanks. I'll fix it ASAP.
