English by Google
Hi:
Can one know if the OS is W7?
TIA
jouhmg
Español
Hola:
¿ Se puede saber si el SO es W7 ?
Gracias
jouhmg
Knowing if W7
- mustafa
Re: Knowing if W7
Hello
I think with: WindowsVersion ()
can determine the version of windows
Gretings
Hola
creo que con: WIndowsVersion()
se puede saber la versión de windows
Gretings
Hola
Re: Knowing if W7
Hi jouhmg,jouhmg wrote:
Hi:
Try to add the following C-function in your project:
HB_FUNC( ISSEVEN )
OSVERSIONINFO osvi;
ZeroMemory(&osvi, sizeof(OSVERSIONINFO));
osvi.dwOSVersionInfoSize = sizeof(OSVERSIONINFO);
GetVersionEx(&osvi);
if (osvi.dwMajorVersion == 6 && osvi.dwMinorVersion == 1)
hb_retl(TRUE);
hb_retl(FALSE);
If IsSeven()
MsgInfo('Windows 7 is detected!')
EndIf
- mustafa
Re: Knowing if W7
Hello I found this magnificent function
created by our great friend Bicahi Esgici
called MsgMulti
On my computer tells me ----> Windows XP
Professional Service Pack 2 Build 2600 <-----
If it can not be used to see if it is
Windows 7 installed
Greetings
Hola he encontrado esta magnifica función
creada por nuestro gran amigo Bicahi Esgici
que se llama MsgMulti
En mi Pc me indica ----> Windows XP
Profesional Service Pack 2 Build 2600 <-----
No se si puede servir para ver si está
instalado Windows 7
called MsgMulti
Windows 7 installed
Greetings
instalado Windows 7
- demoMsgMulti.zip
- (693.97 KiB) Downloaded 306 times
Re: Knowing if W7
English by Google
Hi:
Thanks, but I think it only goes to W. Vista.
jouhmg
Español
Hola:
Gracias, pero creo que sólo llega a W.Vista.
jouhmg
Hi:
jouhmg
Español
Hola:
jouhmg
Re: Knowing if W7
Hello Mustafa!
I've ran this program on my notebook with Win 7 Home Premium 64bit and I've got only:
Home Edition Build 7600
- HMG Founder
Re: Knowing if W7
WindowsVersion() function must be updated to work with Win7. I've added to the current bug list.jouhmg wrote:English by Google
Hi:
TIA
jouhmg
Español
Hola:
Gracias
jouhmg
Meanwhile, you could use the Grigory function or two functions already present in HMG:
- WINMAJORVERSIONNUMBER()
- WINMINORVERSIONNUMBER()
For Win7 these functions will return 6 and 1 respectively. ie:
msginfo ( str (WINMAJORVERSIONNUMBER()) + ' ' + str(WINMINORVERSIONNUMBER()) )
ehhh... yes... the Windows 7 version number is 6.1
Re: Knowing if W7
English by Google
Hi:
Thanks to all.
jouhmg
Español
Hola:
Gracias para todos.
jouhmg
Hi:
Thanks to all.
jouhmg
Español
Hola:
Gracias para todos.
jouhmg
