How to build menu like old ACHOICE function?
Hi guys!
I want to place on the form menu, which should look and work like old ACHOICE function.
I've tried to use grid or listbox::
	aMenuMain := {;
		{"Opcja 1"} , ;
		{"Opcja 2"} , ;
		{"Opcja 3"} ,;
		{"Opcja 4"} ,;
		{"Opcja 5"} }
	aMenuList := {"Opcja1","Opcja 2", "Opcja 3", "Opcja4", "Opcja 5", "Opcja 6", "Opcja 7", "Opcja 8", "Opcja 9", "Opcja 10", "Opcja 11" }
		@ 10,10 GRID Grid_1 ;
			WIDTH 400 ;
			HEIGHT 20*(len(aMenuMain)+1) ;
			HEADERS {'MENU MAIN'};
			ITEMS aMenuMain ;
			WIDTHS {400};
			COLUMNCONTROLS { aCtrl_1 } ;
			On DblClick	WyborOpcji()
		@ 10,500 LISTBOX L_1 ;
			WIDTH 200 ;
			HEIGHT 20*(len(aMenuList)) ;
			ITEMS aMenuList;
			FONT "ARIAL CE" SIZE 11;
			On DblClick WyborZListy()
It looks and works similar.
But - at right side scrollbar always appears - I don't want it.
Has anybody any idea (or working code) how to realise it?
Best regards, Marek
Re: How to build menu like old ACHOICE function?
Hi Mol,
You can make a list of labels to display the menu.
I can not imagine anything better. :?
best regards,
luis vasquez
Hi Mol,
some time ago I did a test with a menu label + picture ... I did not like much, but they are testing to do.
best regards
luis vasquez
Good question marek .... :?:
I made east example to prove visually like quedaria and without worrying to me more about another thing than that. in order to execute the event onclick of label podria to be used ON KEY… it's only one idea.
best regards,
luis vasquez.
It will be difficult to realise with ON KEY, because I'm using .dbf file to store menu tree. And all menus are builded during runtime.
Most of all, I had arrow keys on my mind...
I'm sure, Rathi has possibilities to build such a user component like achoice menu.
What do you think, Rathi?
jucar_es
Post by jucar_es »
adjunto una funcion que yo uso la cual puede adaptar facilmente,
espero le sea util
P_CHOICE.zip
(774 Bytes) Downloaded 424 times
Fine working!
Many thanks!
But still, it isn't what I'm want...
regards, Marek
I have a question to Roberto:
Is it possible to define listbox without scrollbar?
