GRID control and RLOCK()
raumi75
Post by raumi75 »
Hello Roberto,
I use the GRID control with PGRDD (Postgresql RDD). Unfortunately, pgrdd has a flaw: It does not support RLOCK()
It is usually no problem at all. My program runs fine, without rlock.
This is not an hmg-bug, but it causes some problems when saving data in a data-bound grid.
When the grid-control saves data, it tries to rlock the table (h_grid.prg in line 2098).
I tried to come up with a quick fix to the problem. and added IF RDDNAME() # "PGRDD". I know, it is very ugly, but does the trick. Postgresql does not need to be locked explicitly, so there should be no harm done.
So line 2098 of h_grid.prg looks like this:
* If unable to lock return
   if RDDNAME() # "PGRDD" && raumi75
      If Rlock() == .F.
         MsgExclamation(_HMG_SYSDATA [ 136 ][9],_HMG_SYSDATA [ 136 ][10])
         &cRecordSource->(dbgoto(nRecNo))
         return .f.
   endif && raumi75
and line 2112 now looks like this.
   * Unlock
   	&cRecordSource->(dbrUnlock(&cRecordSource->(recno())))
   endif && raumi75
It worked and my data gets saved.
But now I ran into the next problem:
The function DataGridRefresh(index) loads an array of values:
aValue := _GetValue (  ,  ,  index )
This does not work. The value aValue [1] is empty.
I would really appreciate your help. I am stuck.
Re: GRID control and RLOCK()
raumi75 wrote:Hello Roberto,
Thanks for the report.
I've started to work on both issues.
raumi75 wrote: <...>
I've fixed the PGRDD problem (I've was already fixed for SQLMIX) but I've not found any problem with getting grid value.
I've modified Grid.25 sample and added the following line to the menu:
				ITEM 'Get Value'				ACTION ( aValue := Form_1.Grid_1.Value , MsgInfo( Str( aValue [1] ) + ' , ' + Str( aValue [2] ) ) )
And it works fine.
Please, let me know in which context it fails.
raumi75
Post by raumi75 »
Hello Roberto,
thank you for the quick reply.
Getting a value from the grid is no problem. I checked it in the sample and in my application.
The problem seems to be in h_grid.prg around line 2165.
Function DataGridRefresh(index)
Static cRecordSource := ''
Static aColumnFields := {}
	cRecordSource	:= _HMG_SYSDATA [ 40 ] [ index ] [ 10 ]
	aColumnFields	:= _HMG_SYSDATA [ 40 ] [ index ] [ 11 ]
	nHandle	:= _HMG_SYSDATA [ 3 ] [ index ]
	nInitialLogicalPos := aValue [1]
* Here comes the problem:
   if empty(aValue [1])
       msgbox("aValue [1] is empty")
	nDeltaRow := LISTVIEW_GETTOPINDEX ( nHandle ) - aValue [1] + 1
The function SaveDataGridField calls DataGridRefresh whenever "initial logical position is different from Final logical position." It might be a rare case with other RDDs, but I get this condtion everytime. As you can see, I inserted the msgbox-Dialog, to see if aValue is empty.
Hope this helps a little :-)
Raumi
I'm very sorry, but I guess that I'm not understanding...
Please, send me a complete sample showing the situation when the value property returns a wrong value.
TIA.
raumi75
Post by raumi75 »
Roberto Lopez wrote: I'm very sorry, but I guess that I'm not understanding...
TIA.
I feel terrible, that I can't explain it easier. I will try to show my problem with a sample.
Given: I use a table called test. It has the columns garken (C), eigenschaft (C), wert (C) and id (N).
I took GRID.30 and modified it to use a postgresql-server. It works fine, when I use the dbf-table. But when I use a postgresql-table, the sample looks like this.
* MiniGUI Virtual Grid Demo
* (c) 2009 Roberto Lopez
* Modified by raumi75 to show problem mit Postgresql
#command USE <(db)> [VIA <rdd>] [ALIAS <a>] [<nw: NEW>] ;
            [<ex: EXCLUSIVE>] [<sh: SHARED>] [<ro: READONLY>] ;
            [CODEPAGE <cp>] [CONNECTION <nConn>] [INDEX <(index1)> [, <(indexN)>]] => ;
         dbUseArea( <.nw.>, <rdd>, <(db)>, <(a)>, ;
                    if(<.sh.> .or. <.ex.>, !<.ex.>, NIL), <.ro.>,  [<cp>], [<nConn>] ) ;
         [; dbSetIndex( <(index1)> )] ;
         [; dbSetIndex( <(indexN)> )]
   * Postgresql-Connection
   request PGRDD
   nConn := dbpgconnection( "192.168.1.101;databasename;username;password" )
	* Dynamic Display
	bdDisplay_1 := { || Upper(This.CellValue) }
	bdDisplay_2 := { || Lower(This.CellValue)  }
	* Grid Column Controls Definitions
	aCtrl_1 := {'TEXTBOX','CHARACTER'}
	aCtrl_2 := {'TEXTBOX','CHARACTER'}
	DEFINE WINDOW Form_1 ;
		WIDTH 800 ;
		HEIGHT 510 ;
		TITLE 'Hello World!' ;
		MAIN
		DEFINE MAIN MENU
			POPUP 'File'
				ITEM 'Append (Alt+A)'				ACTION Form_1.Grid_1.Append
				ITEM 'Save Last Appended Record (Alt+S)'	ACTION Form_1.Grid_1.Save
				ITEM 'Set RecNo'				ACTION Form_1.Grid_1.RecNo := val(InputBox('',''))
				ITEM 'Get RecNo'				ACTION MsgInfo( Str(Form_1.Grid_1.RecNo) )
				ITEM 'Delete'					ACTION Form_1.Grid_1.Delete
				ITEM 'Recall'					ACTION Form_1.Grid_1.Recall
			END POPUP
		END MENU
      use "SELECT * FROM test WHERE garken = 'VISION    ' ORDER BY id;" alias Test NEW via "pgrdd" connection nConn
		@ 10,10 GRID Grid_1 ;
			WIDTH 770 ;
			HEIGHT 440 ;
			HEADERS {'Column 1','Column 2'} ;
			WIDTHS {140,140};
			EDIT ;
			VALUE { 1 , 1 } ;
			COLUMNCONTROLS { aCtrl_1 , aCtrl_2 } ;
			ROWSOURCE "Test" ;
			COLUMNFIELDS { 'eigenschaft' ,  'wert'} ;
			ALLOWAPPEND  ;
			BUFFERED ;
			ALLOWDELETE ;
			DYNAMICDISPLAY	 { bdDisplay_1 , bdDisplay_2 } ;
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
When I run the program, It displays very well. But: When trying to exit a field after editing it, I get the following error:
Error BASE/1082 Argument error: -
Called from DATAGRIDREFRESH(2176)
Called from SAVEDATAGRIDFIELD(2145)
Called from _HMG_GRIDINPLACEEDITOK(1217)
Called from (b)_HMG_GRIDINPLACEEDIT(794)
Called from _DOCONTROLEVENTPROCEDURE(4919)
Called from EVENTS(563)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4583)
Called from _HMG_GRIDINPLACEEDIT(963)
Called from EVENTS(2624)
Called from _ACTIVATEWINDOW(4561)
Called from MAIN(75)
The line number DATAGRIDREFRESH(2176) is different from your line number, because I fixed the RLOCK()-Postgresql-Bug and added the if empty(aValue [1]) lines which I quoted a few hours ago. It refers to the line
in your file C:\hmg\SOURCE\h_grid.prg
aValue [1] is empty, so the "- Operation" fails.
I know, I sound confusing and I am sorry for not keeping it simpler.
Thank you for taking the time to listen to me.
Raumi
raumi75 wrote: I feel terrible, that I can't explain it easier. I will try to show my problem with a sample.
Ok.
I must to recreate the complete environment to test it and try to find a solution.
I'll try to do, but it could take some time...
Apparently the basic problem is that the Postgre RDD is not behaving exactly the same as standard rdds.
If aValue [1] is zero, it could indicate that due to some reason, no cell is selected. Is that the case?
TIA.
raumi75
Post by raumi75 »
Ok.
TIA.
You are right.
To test your assumption, I added the following lines to DataGridRefresh in h_grid.prg
msgbox("index: "+str(index)+ "Row: "+str(This.QueryRowIndex)+"Col: "+str(This.QueryColIndex) )
When I rund SAMPLE\GRID30, it returns an index of 7 and the correct Row and Col. But when I run my modified Sample with pgrdd, index is 7, but Row and Col is 0! :-(
I have no explanation, why this happens. Did you see the other post about _GetValue being empty? I am not the only one. Somehow this makes me feel better. ;-)
Raumi
Raumi
Well... I have some explanations now, but not all of them :)
There is, at least, one big problem:
Apparently OrdKeyNo() and OrdKeyGoTo() are not working with PostGre RDD the same way as in standard rdds.
With standard rdds, when no index is active, these functions behaves like recno() and dbgoto(). With Postgre rdd, no.
This is reasonable since this rdd does not support indexes.
The problem is that Grid rely heavily on these functions to work.
Moreover, could be other incompatibilities to solve.
Since it will require lots of coding and tests, I'll delay this fix until 3.0.22.
I've discovered some other problems.
Apparently Postgre RDD does not allow to modify records in the usual way.
I've created a database called 'data1', a table called 'table1' with two columns named 'field1' and 'field2', both type character (32).
When I do the following:
dbappend()
replace field1 with "John"
replace field2 with "Smith"
It works.
But if I do:
Go Top
I obtain the following error message:
PGRDD/3000 Data type error, Cannot insert in a joined table, or unknown error
So, at the moment, I don't know how to modify a record :)
This is the complete code:
   request PGRDD
   nConn := dbpgconnection( "127.0.0.1;data1;postgres;1234" )
      WIDTH 800 ;
      HEIGHT 510 ;
      MAIN
      use "SELECT * FROM table1 ;" alias Test NEW via "pgrdd" connection nConn
* This works
	dbappend()
	replace field2 with "Simith"
* But attempting to change, fails:
	go top
	replace field1 with "*"
	dbcommit()
Any help is welcome.
