Alternate syntax
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Alternate syntax
Post by karweru »
Hi Friends,
Please pardon me, for I'm sure I've sought help on this before.
When I compile the following,
#include "minigui.ch"
#include "hbclass.ch"
FUNCTION main()
local cWindowName:="win_1"
local nRow:=0
local nCol:=0
local nWidth:=400
local nHeight:=200
local cTitle:="Hello world"
DEFINE WINDOW (cWindowName)
ROW (nRow)
COL (nCol)
WIDTH (nWindth)
HEIGHT (nHeight)
WINDOWTYPE MAIN
TITLE (cTitle)
ACTIVATE WINDOW (cWindowName)
...I get the following compile error.
Harbour 2.0.0beta3 (Rev. 12765)
Copyright (c) 1999-2009, http://www.harbour-project.org/
C:/classy/demo.prg(12) Error E0030 Syntax error "syntax error at 'WINDOW'"
C:/classy/demo.prg(22) Error E0030 Syntax error "syntax error at 'MAIN'"
2 errors
No code generated.
hbmk2: Error: Running Harbour compiler (embedded). 1
(C:\hmg\harbour\bin\harbour.exe) -n2 C:/classy/demo.prg /q -o.hbmk\win\mingw\ -iC:/hmg/harbour/include -iC:/hmg//include -iC:/classy -iC:/classy/
Please assist me to resolve the problem. If the parenthesis around cTitle are removed, the line also returns a "syntax error at 'CTITLE'"
Kindly assist.
Kind regards,
Gilbert.
Re: Alternate syntax
Hi Gilbert,
In alternate syntax, a line can be broken to multiple lines only in the case of controls. Not in the case of windows, toolbar, tab and status bar.
So, you have to write,
FUNCTION main()
local nRow:=0
local nCol:=0
local nWidth:=400
local nHeight:=200
DEFINE WINDOW &cWindowName ROW nRow COL nCol WIDTH nWidth HEIGHT nHeight WINDOWTYPE MAIN TITLE cTitle
ACTIVATE WINDOW &cWindowName
karweru
Post by karweru »
Waoh!! It Works!!!
I have no words to thank you Rathi!
God bless you.
Kind regards,
Gilbert.
