Getfile problem with nochangedir
l3whmg
Post by l3whmg »
Hi at all,
I found a problem with "GetFile" and "PutFile" functions.
I'm using this syntax:
Getfile( aFilter, cPrompt, cDir, .F., .F.)
But, the last parameter (NoChangeDir) don't work properly.
I have attached an example, with suggestion.
If you try the example, remember to change the directory, from the current one, to see the problem.
Ciao!
GetFileTest.zip
Example
(897 Bytes) Downloaded 328 times
Luigi from Italy
www.L3W.it
Re: Getfile problem with nochangedir
l3whmg wrote:Hi at all,
Ciao!
Thanks for the report.
I'll review it ASAP.
Ciao!
You have an error in line #63.
your code:
cFile := Getfile( { {'All Files','*.*'} }, "File selection", cBefore, .F., .F.)
it should be:
cFile := Getfile( { {'All Files','*.*'} }, "File selection", cBefore, .F., .T.)
l3whmg
Post by l3whmg »
Yes,
I'm sorry :oops: . I've looked now with your suggestion. I've copied an old program without a good test before and, perhaps, this was an old problem!
Thanks a lot.
Luigi from Italy
www.L3W.it
