Connecting to an Oracle Database
Posted: Thu Jan 14, 2010 7:22 pm
by melliott42
Hello,
I need to write some applications that connect to an Oracle database. I have created a wrapper function that can do this but it is very kludgey. It writes a SQL script on-the-fly, runs the script in SQLPlus then gets the output via a spool file. Yuck! :(
Is there an easy way to interact with an Oracle database using HMG?
The versions I need to access are 10g and 11g.
Thanks,
Michael
Re: Connecting to an Oracle Database
Posted: Thu Jan 14, 2010 8:00 pm
by Roberto Lopez
melliott42 wrote:Hello,
Thanks,
Michael
I've never used Oracle, but I guess that it could be done via RDDSQL.
Look at \hmg\samples\rdd.sql\mdb.
If you can get an ODBC connector for Oracle and modify the connection string as required, it could work.
Posted: Thu Jan 14, 2010 11:09 pm
by luisvasquezcl
Hi Michael
you can see in http://www.connectionstrings.com/oracle
best regards,
Luis Vasquez
Posted: Tue Jan 19, 2010 3:50 pm
by MigSoft
Interesting link about it
http://www.ajpdsoft.com/modules.php?nam ... le&sid=272
MigSoft
Posted: Tue Jan 19, 2010 4:23 pm
by luisvasquezcl
Hola Miguel,
como siempre, un excelente aporte.
Gracias.
Saludos cordiales,
Luis Vasquez
