DynamicColor of one Column depending on other Column
Hello Friends,
This is the smallest and the simplest project I want to share with you ;) . But, forgive me, I can't just resist myself to share the very simple solution I got (thinking 3/4 days :o :lol: ), with you :)
I forgot to mention, this small sample was created from tips by Master Roberto Lopez. Thank you master :)
I want to change DynamicForeColor of a Column of a Grid depending on the value of another column of the same grid.
Here is the source code
DynamicColor.zip
(2.48 KiB) Downloaded 436 times
Re: DynamicColor of one Column depending on other Column
Hi Sudip,
Thanks for sharing. :)
sudip wrote:Hello Friends,
DynamicColor.zip
If you are trying to change the forecolor for column 2 based on column 2 content:
Please, replace your DynColor function with this:
Function DynColor(mRow, mCol)
local r
	if mCol == 2
		if frmAtten.grdAtten.cell(mRow, 2) = 1
			r := {0, 0, 0}
			r := {0, 255, 0}
		r := {0, 0, 0}
return r
If you are trying to change the forecolor for column 1 based on column 2 content:
local r
	if mCol == 1
			r := {0, 0, 0}
			r := {0, 255, 0}
		r := {0, 0, 0}
return r
Hello Master Roberto,
Thanks a lot for checking this small sample and for your tips :)
My original sample was also built on your tips :)
Thank you again.
Rahi, it's the beauty of HMGForum that creator of very small things (like me), also encouraged to do better :) Thank you :)
If someone asks me what is the best thing of Clipper and Harbour, I will say, "Code Block". But, unfortunately I am not very easy with it ;)
