List of all defined controls in a form
l3whmg
Post by l3whmg »
Hi at all,
I don't know if exist (I don't find / don't read about), but is there a function that return an array with the names of all defined controls in a form?
Luigi from Italy
www.L3W.it
l3whmg
Re: List of all defined controls in a form
Post by l3whmg »
and sorry :oops: : after I've inserted this post I understand that it's not so clear the use.
I want execute a loop to disable all the controls in a form. Example:
aControl := MiniGuiFunction()
FOR n := 1 TO LEN(aControl)
 aControl[n].Enabled := .F.
NEXT n
Bye
Luigi from Italy
www.L3W.it
Yes. You can do easily.
Please consider the example below using GetWindowControls(cForm) user defined function.
# include "minigui.ch"
function main
define window sample at 0,0 width 800 height 600 main
   define label label1
      row 10
      col 10
      width 100
      value "Label 1"
   end  label
   define textbox text1
      row 10
      col 110
      width 120
      value "Sample Text Box 1"
   end textbox
   define label label2
      row 40
      col 10
      width 100
      value "Label 2"
   end  label
   define textbox text2
      row 40
      col 110
      width 120
      value "Sample Text Box 2"
   end textbox
   define label label3
      row 70
      col 10
      width 100
      value "Label 3"
   end  label
   define textbox text3
      row 70
      col 110
      width 120
      value "Sample Text Box 3"
   end textbox
   define button action1
      row 100
      col 10
      width 100
      caption "Press here"
      action dolisting()
   end button
   define listbox list1
      row 130
      col 10
      width 200
      height 200
   end listbox
end window
sample.center
sample.activate
return nil
function dolisting
local aControls := GetWindowControls("sample")
local i := 0
sample.list1.deleteallitems()
for i := 1 to len(aControls)
   sample.list1.additem(aControls[i])
next i
if sample.list1.itemcount > 0
   sample.list1.value := 1
return nil
function GetWindowControls(cForm)
local aControlList := {}
local i := 0
for i := 1 to len(_HMG_SYSDATA[4])
   if _HMG_SYSDATA[4,i] == GetFormHandle(cForm)
      aadd(aControlList,_HMG_SYSDATA [  2,i])
next i
return aclone(aControlList)
l3whmg
Post by l3whmg »
Hi Rathinagiri,
many, many thanks: I've used your information :mrgreen: .
Every day I discover :o the capabilities of MiniGui.
Bye
Luigi from Italy
www.L3W.it
l3whmg
Post by l3whmg »
Hi Rathinagiri,
I compiled and tested your program and it works fine. I applied your suggestion to my program, using the "setProperty", but I found some anomaly; in the vector, which should contain the names of the active controls, there are some invalid entries, please, can you compile the source that I've posted and tell me if you have the same like me?
A) select the "Menu" and then " GetControl" on the main menu: three times in succession, the message returns Empty values and then (correctly) "lb_ prgcodice " and "prgcodice";
B) select the "Modal" and then "TestWindow" on the main menu and then the " GetControl", I get this sequence of messages: "StatusTimer", "StatusBar", "toolbar1", "bt_exit", Empty, "bt_save" , Empty, "lb_prgcodice", "prgcodice";
There are a lot of unused functions, but this source is a little "skeleton" of my sorurces.
I made mistakes? Have you the same?
Many thanks in advance
mytest.zip
simple source
(969 Bytes) Downloaded 818 times
Luigi from Italy
www.L3W.it
Hi Luigi,
You didn't make any mistakes. I had made. :)
For menu items and toolbar separators, we don't have names. But, they are also controls.
Now please consider this function.
STATIC FUNCTION GetWindowControls(cForm)
local i := 0
      if len(alltrim(_HMG_SYSDATA [  2,i])) > 0
next i
for i := 1 to len(aControlList)
msgstop(aControlList[i])
next i
l3whmg
Post by l3whmg »
waiting your answer, I do the same :mrgreen:
Luigi from Italy
www.L3W.it
Wise men think alike. :)
