aPrinter() function problem
l3whmg
Post by l3whmg »
Hi at all,
In a network scenario, I had installed and shared one printer. After some time, I had removed the pc (and the printer) where was installed locally that printer, but I not remove from the panel “Installed printers” on the other pc; on this last pc, in Ms Windows XP Pro, I can see this printer in the panel, but with a message like “can not connect…” (I don’t remember exactly the message in WXp English version).
In this scenario, when I call the function “aPrinters()”, the program display an error (like msgstop) and go in a deadlock state and only with the task manager I can kill the process; I’m sorry, but I can’t include an image of the message and I can’t replicate it, because I’ve removed the printer from the “Installed printers” list and the program works fine. On the other hand I think the problem appear only when the printer state is like showed by that message (not when the printer it’s only turned off).
A little question: I’ve read about some printer functions in “hbwin” contribution library (Harbour 2.0.0). I can call these function after MiniGui “SELECT PRINTER…” command using _HMG_SYSDATA[374] value as reference? Because I’ve create one little printing library (very simple, not like report interpreter) to print out, but I need to know some information; I think about “win_GetDeviceCaps” or “win_GetCharSize” or “win_GetTextSize” included in hbwin library.
Many thanks in advance.
Luigi from Italy
www.L3W.it
Re: aPrinter() function problem
l3whmg wrote:Hi at all,
Ok.
Its very very important for me that you let me know the message. It could be a good starting point to me to try to work on it.
l3whmg wrote: A little question: I’ve read about some printer functions in “hbwin” contribution library (Harbour 2.0.0).
I've not reviewed such functions in Harbour yet, so I can't help you on this right now.
l3whmg
Post by l3whmg »
Hi Roberto,
I've tried to replicate, but without the same result. At this point I think: or was my program to have problem (but it's the same that I'm using now) or the conditions were not the same.
I take in my mind this event and if come back...
Many, many thanks for your job.
Luigi from Italy
www.L3W.it
l3whmg wrote:Hi Roberto,
Please, do not forget (for this problem and others) to send me all the error messages that you've received. That is extremely important to analyze the problem and get a solution.
l3whmg
Post by l3whmg »
Yes,
the next time I will be more active to store message and situation!
Bye
Luigi from Italy
www.L3W.it
