Scrollbars of Print Preview is not working properly
Hello Master Roberto,
I found scrollbar controls (both vert and horiz) are not working properly.
How I found:
I tested hmg\SAMPLES\REPORT.ADVANCED.8\Demo.
I zoomed within print preview. Then use scrollbar. Scrollbar is not showing it's position correctly.
Please correct me if I am wrong :)
Please check this in your free time :)
Re: Scrollbars of Print Preview is not working properly
Hi Sudip
I've tested hmg\SAMPLES\REPORT.ADVANCED.8\Demo and worked properly.
WinXP SP2 HMG 3.00 XIIIa.
How I found:
It appears to work fine here.
Please, let me know what windows version are you using and which is the exactly problem.
TIA.
Thanks a lot to all of you for testing :)
I am using Windows XP SP2.
Have you tested by dragging the slider of scrollbars?
I've used Win XP Prof. SP3 .
I was dragging by slider and clicking arrows.
Everything looked OK.
Marek
PS.
Scrolling with wheel works good, too
mol wrote:I've used Win XP Prof. SP3 .
Marek
PS.
Hello Marek,
Thanks a lot for your prompt reply.
Can you please test again by clicking on the scrollbar between the slider and any of the 2 clicking arrows. In that case slider should move, but in my system it doesn't move properly.
Sorry for giving you trouble.
Thanks in advance.
Marek
PS.
Hello Marek,
Thanks in advance.
Ok. I've verified the problem.
It appears only when you use the arrows (not the scrollbar button).
Thanks for reporting.
