I have a very minor wish. Is it possible to add date format property of DatePicker control?
May be there is another way to do it. So, please correct me if I am wrong
Thanks in advance.
I put set date command in the start up of my app. It works for textbox with date type, but in my client's computer I found date picker control showing date in m / d / y format. I changed date format from Regional control of control panel. Date picker format didn't change. Funny thing is that it's working fine in my laptoprathinagiri wrote:set date command is not working?
Most probably yes. But, I shall confirm when I shall visit there in next weekrathinagiri wrote:Had you restarted the system?
Datepicker is based on a Windows control (datetimepicker).sudip wrote:Hello Master Roberto,
May be there is another way to do it. So, please correct me if I am wrong.
Thanks in advance.
I've already researchedRoberto Lopez wrote: I'm not sure if that behavior could be changed. It should be researched.
NiceRoberto Lopez wrote:I've already researchedRoberto Lopez wrote: I'm not sure if that behavior could be changed. It should be researched.
Yes. It can be done.
It is in my TODO list.
