buttons picture on toolbar disappear
l3whmg
Post by l3whmg »
Hy guys,
I need your help.
When I execute my program (that is more functions together and “any” function have it’s form), many times all/someone picture on the toolbar disappear :( , but…magically if I leave current form and recall it (one or more times from main menu) the buttons picture come back :o . I’ve included a zip file with: Shot01.jpg (with problem) and Shot02.jpg (without problem), toolbar.prg (toolbar definition in my functions inside any form), my “nbuild.bat” (I’ve do some modification) to explain how I’m using windres.exe (I adding my pictures adding extra .rc file) and one bitmap file.
I’m compiling on MSWinXpPro with “HMG 3.0.0 Test XIII (2009.12.23)” but I remember the same problem with HMG2.0;
I've create my bitmap files with Gimp.
Someone have one idea?
Thanks a lot in advance and sorry for my bad English :oops: .
ErroreBottoni.zip
(10.7 KiB) Downloaded 305 times
Luigi from Italy
www.L3W.it
Re: buttons picture on toolbar disappear
l3whmg wrote:Hy guys,
I need your help.
Please post a complete (compilable) sample showing the problem, then, I'll analyze it.
TIA.
Ricci
Post by Ricci »
Luigi,
do you use a "pure Windows" or did you have any shell or taskbar addons to get a better look ?
HMG programs don´t like the snapshot function of some utilities (i.e. NextStart).
Regards ... Ricci
l3whmg
Post by l3whmg »
Hi guys,
many thanks but today I've find solution :)
The problem was the procedure that I’ve used to create bitmap pictures with Gimp; I don’t know if the new procedure it’s the correct way, but solve my problem.
For every newbe (like me :mrgreen: ) some topics:
1) Yes, I use layers (inside .xcf) with transparency background, but there is one layer (filled with color ECE9D8) that I turn on before save bmp picture.
2) When I save .bmp file I use "Unisci livelli" (Eng. "Merge Layers" - I think)
3) MOST important I use "Opzioni avanzate" (Eng. "Advanced setting" - I think) and I select 24bits (R8G8B8)
I've included image about saving procedure (Gipm Italian Language) to better explain.
In previous procedure a) I don't have used a layer with color and b) I have used 32bits (A8R8G8B8).
I think the problem was an "incorrect" loading or recognizing of the bitmap inside the exe.
And now the question: this have solved my problem, but is it the correct way or is there another way?
A little note: if I don't use the layer filled with one color, the pictures on the toolbar have a white background.
ScreenShot.zip
(30.64 KiB) Downloaded 337 times
Luigi from Italy
www.L3W.it
