Changing SQLite Table Structure Online
Hello All,
We always need to change our existing table structure during creation or updradation of a project. If we use dbf it is very easy (I created one during Clipper days and it works fine till now. I you want I shall publish it again :) ). But, I don't have any function like this when we are using SQL table (especially using Sqlite).
Can anyone help me regarding this ?
Thanks in advance :)
arroya2
Re: Changing Table Structure Online
Post by arroya2 »
En Español:
Hola Sudip
Te agradeceré me indiques como hacerlo en DBF. Abrí un tema preguntándolo pero nadie me contestó.
Rafael Pérez
In English by Google:
Hi Sudip
Thank you show me how to do it in DBF. I opened a topic asking it but nobody answered.
Greetings
Rafael Perez
Hello Rafael,
I am very much happy to share my code with you all :) Here is it :-
(Please remember, I should use new temporary table feature of Harbour in the following code.)
#include "dbstruct.ch"
#include "minigui.ch"
FUNCTION dbCreaChk(fname, adbf)
   local aStruct, option, lChange := .f., lNew := .f., i, newrec, oldrec
   fname := upper(fname)
   if !file(fname+".dbf")
      set exclusive on
      dbcreate(fname, adbf)
      set exclusive off
      return .t.
   use (fname)
   aStruct = dbstruct()
   use
   if len(aStruct) != len(adbf)
      lChange = .t.
      i = 1
      do while i <= len(aStruct) .and. !lNew .and. !lChange
         if len(aStruct[i, DBS_NAME]) != len(adbf[i, DBS_NAME]) ;
            .or. upper(aStruct[i, DBS_NAME]) != upper(adbf[i, DBS_NAME]) ;
            .or. upper(aStruct[i, DBS_TYPE]) != upper(adbf[i, DBS_TYPE]) ;
            .or. aStruct[i, DBS_LEN] != adbf[i, DBS_LEN] ;
            .or. aStruct[i, DBS_DEC] != adbf[i, DBS_DEC]
            lChange = .t.
         i++
      enddo
   if lChange
      if msgyesno(fname+" structure has been changed. Change";
                                   +" the structure ?")
         set exclusive on
         use (fname)
         pack
         oldrec = reccount()
         use
         deletefile("settemp.dbf")
         if renamefile(fname+".dbf", "settemp.dbf") != 0
            msginfo("Cannot change file structure!",)
            QUIT
         use (fname)
         append from settemp
         newrec = reccount()
         use
         if newrec != oldrec
            msginfo("Problem in creating file :"+fname+;
                   ". You can get all records in the file SETTEMP.DBF")
            quit
         set exclusive off
         return .t.
         msginfo(fname+" structure mismatch")
         quit
   return .f.
function NetSelect(cTable)
   if select(cTable) = 0
      use &cTable shared new
   select (cTable)
   return nil
I shall be very happy if above code will be helpful :)
arroya2
Post by arroya2 »
En Español:
Hola Sudip.
Muchas gracias por compartir tu código.
Lo voy a poner en práctica enseguida.
Muy agradecido
Rafael Pérez
Hi Sudip.
Thank you very much for sharing your code.
I'm going to put into practice right away.
Very been thankful
Rafael Perez
I just created very simplified code to change Sqlite table structure online (from hints of Rathinagiri) using codes from Rathi and Grigori Filatov :)
//Usage: AddField(mDb, "sale", "test", "text default 'testing'")
Function AddField(mDb, mTblNm, mFldNm, mFldDesc)
   local lFound := (ascan(SQLITE_TABLES(mDb, mTblnm), {|x| upper(x[1]) == upper(mFldnm)}) > 0)
   if !lFound
      miscsql(mDb, "ALTER TABLE "+mTblNm+" ADD COLUMN "+mFldNm+" "+mFldDesc)
   return nil
// Following code is written by Grigory Filatov (Minigui\Samples\Advanced\Sqlite_2\Demo.prg)
 FUNCTION SQLITE_COLUMNS( db, cTable )
* Returns an 2-dimensional array with field names and types
  LOCAL aCType :=  { "SQLITE_INTEGER", "SQLITE_FLOAT", "SQLITE_TEXT", "SQLITE_BLOB", "SQLITE_NULL" }
  LOCAL aFields := {}, cStatement := "SELECT * FROM " + cTable
  LOCAL stmt, nCCount, nI, nCType
  stmt := sqlite3_prepare( db, cStatement )
  sqlite3_step( stmt )
  nCCount := sqlite3_column_count( stmt )
  IF nCCount > 0
	FOR nI := 1 TO nCCount
		nCType := sqlite3_column_type( stmt, nI )
	        AADD( aFields, { sqlite3_column_name( stmt, nI ), aCType[ nCType ] } )
	NEXT nI
// taken from HMG300\SAMPLES\SQLITE\SQL1.PRG
// as per I remember, written by Rathinagiri
function miscsql(dbo1,qstr)
if empty(dbo1)
   msgstop("Database Connection Error!")
   return .f.
sqlite3_exec(dbo1,qstr)
if sqlite3_errcode(dbo1) > 0 // error
   msgstop(sqlite3_errmsg(dbo1)+" Query is : "+qstr)
   return .f.
return .t.
Thanks a lot to Rathi and Grigory :)
Re: Changing SQLite Table Structure Online
Thanks a lot Sudip.
Hello Friends,
My previous code has serious mistakes :(
Corrected code will be:
   local lFound := (ascan(SQLITE_COLUMNS(mDb, mTblnm), {|x| upper(x[1]) == upper(mFldnm)}) > 0)
   if !lFound
   return nil
One thing more, if you are using SQLite Browser from http://sqlitebrowser.sourceforge.net, today it deleted one table during adding one column ;)
sudip wrote:...
Now, I downloaded the latest version of SQLiteBrowser. They solved the problem :D
