TMsAgent
Steed
TMsAgent
Post by Steed »
I left my first project in Hmg, it was one adaptation of the class TMsAgents of Juan Carlos Salinas Ojeda , this application can speech the text that you put in Spanish or English, but, as Gregory said "You'll need the Microsoft Agents which are installed on your system (f.e., Merlin, Peedy etc.)." see http://www.microsoft.com/msagent/downloads.htm
7z.File included sources+Exe
Eduar
TMsAgent22.7z
(592.88 KiB) Downloaded 494 times
Re: TMsAgent
Thanks for sharing Steed.
Re: TMsAgent
Hola Steed.
Felicidades por la aplicación está muy bien , perdona la molestia,
podrias poner un pequeño ejemplo, mas simplificado , solo lo basico
que se necesite para poder incorporarlo en las aplicaciones.
Gracias , un saludo
Hi Steed.
Congratulations on your application is fine, pardon the inconvenience,
could put a small example, more simplified, only the basics
be required to incorporate into applications.
Thanks, greetings
claudiotedesco
Re: TMsAgent
Post by claudiotedesco »
Perdon mi ignorancia pero esto es Free o hay que abonar algo para usar este control?
Gracias.
Claudio
Pardon my ignorance but this is Free or you have to pay anything to use this control?
Thank you.
Re: TMsAgent
Hello Eduar,
Please take a look for the following link
http://www.microsoft.com/products/msagent/main.aspx
Windows 7 and later versions will not support development of Microsoft Agent applications or characters
Steed
Re: TMsAgent
Post by Steed »
Grigory
It's a sad notice :(
Mustafa, attached please find short sample,
Test.7z
(13.34 KiB) Downloaded 429 times
Re: TMsAgent
----------- Agent Simplificado --------------
Hola me está dando error en:
undefined reference to `HB_FUN_CAS_MOUSE'
undefined reference to `HB_FUN_TMSAGENT'
estoy compilando con HMG 2.9.5
he compilado solo con los ficheros siguientes
el TEST. prg último que has mandado
Test.prg
TMsAgent.Ch
DlgBallon.Fmg
---------- Simplified Agent -----------
Hi I'm getting error:
undefined reference to `HB_FUN_CAS_MOUSE '
undefined reference to `HB_FUN_TMSAGENT '
I am compiling with HMG 2.9.5
I have compiled only with the following files
the TEST. prg last thing you sent
Test.prg
TMsAgent.Ch
DlgBallon.Fmg
Thank you for your dedication
Steed
Re: TMsAgent
Post by Steed »
Mustafa,
I', using hmg300 Test 12. I update the file test.7z (in this post) please re-download it again.
At least you need to use:
Test.prg (your application) plus:
TMsAgent.Prg
DlgBallon.Prg
DlgBallon.Fmg
TMsAgent.Ch
Message.ch
But take in mind that Grigory said "Windows 7 and later versions will not support development of Microsoft Agent applications or characters"
Eduar
Re: TMsAgent
Hola Steed
Me sigue dando error e instalado HMG 300 Test XIII y he
compilado con el bat y con QAC los ficheros
Test.prg
TMsAgent.Prg
DlgBallon.Prg
DlgBallon.Fmg
TMsAgent.Ch
Message.ch
Lo veo muy complicado para mi nivel de programación
Gracias por tu dedicación
Hi Steed
He continues to give error and installed 300 Test XIII and HMG I
compiled with the bat and files QAC
Test.prg
TMsAgent.Prg
DlgBallon.Prg
DlgBallon.Fmg
TMsAgent.Ch
Message.ch
I see it too complicated for my level of programming
Thanks for your dedication
Steed
Re: TMsAgent
Post by Steed »
Mustafa,
Spanish:
Compila con el la ultima version del IDE de roberto y la ultima version de hmg (hmg300 test 12),
No te preocupes como digo Sudip todos somos estudiantes
Saludos,
Eduar
English
Compila with last version of Roberto's IDE and the las hmg version (hmg300 test 12),
Don´t worry as Sudip Said, we all are students.
Regardsm
Eduar
