Funcion GetUserName
Funcion GetUserName
Hola estimados:
quisiera saber si es posible implementar la funcion getusername() o si existe alguna parecida en hmg.
saludos cordiales,
LUis Vasquez
Re: Funcion GetUserName
What this function should to do?
(i don't know GetUserName()...)
Hi Mol,
With this function you can get the user name
computer.
regards,
luis vasquez
You can use this user defined function. :)
Save this libgetenv.a in c:\hmg\lib folder. Add getenv library in your linker list.
Run this simple program:
# include "minigui.ch"
function main
msginfo(getenvironmentvariable("UserName"))
return nil
You can get the current username.
Some other environment variables you can get can be seen here.
http://www.scriptlogic.com/support/Cust ... rence.html
libgetenv.zip
(424 Bytes) Downloaded 1030 times
Alex Gustow
Post by Alex Gustow »
Hmm... But what's wrong (for you, Luis) with "\SAMPLES\BASIC\GetUserName" ?
(DEMO.PRG - file date 2006-12-21)
It works fine (as I can see).
Rathi, thanks for advice about "getenv" library.
Thanks Rathi :)
Muchas gracias a todos por sus respuestas.
Probaré el ejemplo de Rathi.
Estimado Alex, la funcion GetuserName existe en minigui extend pero no en hmg.
Thanks for all
Luis Vasquez
Dear,
I saw the page that Rathi kindly informed us and I find it
may access these environment variables with the command
GETE ( 'var_name').
Again thanks for your support.
Estimados,
Vi la pagina que gentilmente nos informó Rathi y me encuentro que es
posible acceder a esas variables de entorno con el comando
GETE('Nombre_variable').
Nuevamente gracias por su apoyo.
Saludos cordiales,
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Post by karweru »
GETE ( 'var_name').
Waoooh...Thanks everyone. This will be very usefull for me.
Kind regards,
Gilbert.
