IDE 3.0 TEST XIIf
- HMG Founder
IDE 3.0 TEST XIIf
This release features an optimized error tracking window (Thanks to Marek for the report on 'slowness').
I've tested with a 10000 lines source. Reading and writing is almost instantaneous.
I've used some experimental virtual grid new features to achieve this, so be careful. It is highly recommended that you backup your sources before modifying them with error tracking window until it be tested enough.
I've fixed a problem opening projects containing reports in XP.
Thanks to Mario Mansilla and Claudio Tedesco for reports on that.
Please, test and report any problem you found.
TIA.
TIA.
- ide_30_test_12f.rar
- (662.22 KiB) Downloaded 365 times
Re: IDE 3.0 TEST XIIf
Thanks a lot Roberto.
Can this excellent feature be implemented in HMG?
Hello Master Roberto,
Thanks a lot
It works fine
Ide.exe file size is very small (only 648kb!!!
Thanks a lot again
I also want to know about the new experimental virtual grid features.
Thanks a lot
Many thanks Roberto!
Its's wonderful to see how my wishes become reality...
- HMG Founder
Yes. It is working in my 3.0 test XIII right nowrathinagiri wrote:Thanks a lot Roberto.
I'll do more test prior to publish, but I'll do when be sure that it is stable enough.
- HMG Founder
As I've said in other post, it can be achieved using UPX with '--ultra-brute' parameter, but you need a lot of patiencesudip wrote: Ide.exe file size is very small (only 648kb!!!)
Oh! Great.Roberto Lopez wrote:Yes. It is working in my 3.0 test XIII right nowrathinagiri wrote:Thanks a lot Roberto.
Wow! It really works too much faster!
Best regards, Marek
Best regards, Marek
A small doubt:
When we have an error of multiple definition of a function in two places in a project, no error is shown in the dialog. However, build log dialog is opened blank. Can this error be shown in the log window?
