Problem with icons via RC
Ricci
Post by Ricci »
I´m using HMG 3.0 Test XII
I bind the icons for the grafical buttons and small grafics via an RC-File into the program.
When leaving the program in background, working with Firefox and Thunderbird and going back some of the pictures changed completely oder shift a little bit. Sometimes they repair themselves when using IMAGE, but the BUTTONs remained defect.
Please see the picture attaches to the topic with the before - after effect. The above are IMAGEs the lower are BUTTONs.
Regards ... Ricci
Screenshot of the problems
Re: Problem with icons via RC
Ricci wrote:I´m using HMG 3.0 Test XII
Regards ... Ricci
Please, post a small sample showing the problem and indicate which Windows and HMG versions are you using.
TIA.
Ricci
Post by Ricci »
Roberto Lopez wrote:Please, post a small sample showing the problem and indicate which Windows and HMG versions are you using.TIA.
I´m using WinXP SP3 and HMG 3.0 Test XII.
I cannot send a sample because the problem isn´t reproducible. It must be some kind of overlapping with some other programs.
This is the way i define the images and buttons:
@ 359,015 IMAGE lichtF PICTURE "lichtu" WIDTH 35 HEIGHT 25
@ 540,210 BUTTON ButtonCancel PICTURE "bcancel" ACTION ButtonCancelClick() WIDTH 29 HEIGHT 30 FLAT TOOLTIP "Abbrechen"
And i am not sure, if it isn´t only a problem of my computer. Because more than 50 or 100 people are using the program and no one ever complained about that.
Perhaps i find a way to reproduce the error, than we can find out why it happens.
Ricci
Ricci
mmm...
I'm working these days with an XP-SP3 system with HMG 3.0 XII IDE, Firefox and thunderbird and I've not experienced problems (IDE is plenty of buttons with images)...
Ricci
Post by Ricci »
Roberto Lopez wrote: mmm...
I have to check it out on another system, because i found another strange behavior:
I define 4 FRAMEs with
@ 354,010 FRAME pflegerahmen1 WIDTH 131 HEIGHT 33
@ 354,140 FRAME pflegerahmen2 WIDTH 131 HEIGHT 33
@ 354,270 FRAME pflegerahmen3 WIDTH 131 HEIGHT 33
@ 354,400 FRAME pflegerahmen4 WIDTH 130 HEIGHT 33
About 3 seconds after the program has started, it gets a repaint from windows (?) and then the first frame disappears. It is always the first FRAME i define, no matter where the DEFINE is positioned in the program. If i repaint the FRAME after it disappears with a
Form_1.pflegerahmen1.Row := Form_1.pflegerahmen1.Row
then it remains on the screen. Funny thing, my workaound is to define a dummy frame before the 4 real frames.
It's very strange.
I've already extensively tested HMG with XP, Vista and 7 (themed and not themed) and I've not experienced such problems.
Ricci
Post by Ricci »
Roberto Lopez wrote:[
It's very strange.
As i thought before, it´s a conflict of the program with the "Winstep Extreme" desktop enhancement ( http://www.winstep.net/ ).
It´s the "Windows peeking" future, that must be disabled for HMG Programs. "Windows peeking" means the desktop enhancement makes a snapshot of every active program from time to time to present them in the tasklist if go with the mouse pointer over it. Some programs didn´t like this.
Ricci
Ricci wrote: As i thought before, it´s a conflict of the program with the "Winstep Extreme" desktop enhancement ( http://www.winstep.net/ ).
Ricci
Ok.
I don't knew that product.
