FreeRAM memory manager
Hello,
I want to present you a next my program - FreeRAM.
It is a skinable application by HMG :)
FreeRAM is a free memory management program
designed for Windows 9x/ME/NT/2000/XP.
This is done by forcing Windows to remove
all the data that is not currently needed
from the memory. It can be used manually or
automatically.
Enjoy!
FreeRAM.zip
FreeRAM application (updated version)
(554.82 KiB) Downloaded 1076 times
Re: FreeRAM memory manager
Hello Grigory,
Thanks a lot (again and again :) ) for this app :)
But when I tried to run it, I got following errors:
Date: 11/25/09 Time: 20:36:50
Error BASE/1099 Argument error: STR
Called from STR(0)
Called from CPUUSAGE(2313)
Called from CREATESKINEDFORM(188)
Called from (b)MAIN(128)
Called from _PROCESSINITPROCEDURE(1453)
Called from _ACTIVATEWINDOW(1311)
Called from MAIN(142)
I my system has XP SP2 with AVAST antivirus and Outpost Firewall.
BTW, I created a special Folder in my Harddisk named "GrigoryFilatov" to store your utilities :)
Alex Gustow
Post by Alex Gustow »
Hi Grigory!
I use your FreeRam (2 years or more) on my Win98 - small, simple but useful and helpful thing. :)
sudip wrote:Hello Grigory,
Called from STR(0)
Hello Sudip,
Thanks a lot for your bugreport!
You should switch to ON the system monitoring (default is ON) for correct working of the FreeRAM memory manager.
Sorry for any inconvenience!
gfilatov wrote:Hello,
Does it works in Vista/7?
Roberto,
I've uploaded an updated version at the first post. It works smoothly now at WinXP (CPU usage counter was disabled).
Please be so kind to revise this program at Vista/Se7en 8-)
Thanks in advance :!:
Roberto,
I've uploaded an updated version at the first post. It works smoothly now at WinXP (CPU usage conter was disabled).
I've made the question because I've got the same error as Sudip on Win7. I'll try to find a way to configure the system to make it work.
Hello Grigory,
Thanks a lot. Now the updated version works :)
I am very PROUD that this type of system utilities can be created with HMG Official / HMG Extended :)
Looks very nice. :) Useful utility too.
Thanks for sharing.
It runs now, but the help is not working, since in Vista+ systems the .hlp format is not supported.
Perhaps, you should move to a more universal format for help, like HTML or PDF.
MS's 'programmed obsolescence' can be a big problem...
