Welcome to the Project Developers' Table
mrduck
Re: Welcome to the Project Developers' Table
Post by mrduck »
rathinagiri wrote:Thanks a LOT for your update. It is great.
First I want to unite Browse, Grid and VirtualGrid.
There are still some bugs, don't do a new release on today svn !
Ok. I won't.
I want to process the 'enter' or 'return' key to act as a tab key for "set navigation extended".
For this, I took "TextBox" as sample and added a 'connect' like this around in /source/textbox.prg at line number 568.
   ::oQTObject:connect( QEvent_KeyPress , {|e| ::DoControlKeyBoardEvents( e )} )
I have added in control.prg as under.
* control.prg
METHOD DoControlKeyBoardEvents( e ) Class CONTROL
   LOCAL oKeyEvent := QKeyEventFromPointer( e )
   LOCAL nKey := oKeyEvent:key()
   LOCAL nModifiers := oKeyEvent:modifiers()
   LOCAL oNewKeyEvent
   IF (nKey == Qt_Key_Return .and. nModifiers == Qt_NoModifier ) .or.( nKey == Qt_Key_Enter .and. nModifiers == Qt_KeypadModifier )
      oNewKeyEvent := QKeyEvent( QEvent_KeyPress, Qt_Key_Tab, Qt_NoModifier, 'Tab', 0, 1 )
      ::s_qApp:sendEvent( ::oQTObject, oNewKeyEvent )
      oNewKeyEvent := QKeyEvent( QEvent_KeyRelease, Qt_Key_Tab, Qt_NoModifier, 'Tab', 0, 1 )
      RETURN .F.
   RETURN .F.
I could not get it to work. It gives runtime error at sendEvent().
mrduck
Post by mrduck »
There were problems with sendEvents code and they were solved last week, after rev 16420. You need to wait.
Thanks for the info.
Francesco,
Had you updated HMG 4.0 source in line with latest Nightly build?
Or, Shall I start doing?
mrduck
Post by mrduck »
rathinagiri wrote:Francesco,
I'm 24/24 on hbQt now. There is a problem with the new code and we are investigating. So please don't update the hmg-4 sources in svn yet otherwise no-one will be able to compile
Ok Francesco,
I will wait for your signal.
Carlos Britos
Post by Carlos Britos »
mrduck wrote:So please don't update the hmg-4 sources in svn yet otherwise no-one will be able to compile
Hi
I've made Dial class, here is the code to upload if it is accepted.
dial.zip
(2.81 KiB) Downloaded 183 times
2011-04-01 20:00 UTC+0530 Rathinagiri (<srgiri@dataone.in>)
  * source/browse.prg
  * source/datepicker.prg
  * source/monthcalendar.prg
  * source/grid.prg
  * source/listbox.prg
  * source/printer.prg
  * source/windows.prg
  * source/virtualgrid.prg
    * Changes according to the latest version of HBQT. Thanks for the contribution by Francesco.
Please don't commit until a new version along with the latest HBQT is released. I will do it today or tomorrow.
