NC Clone
Re: NC Clone
have fix Modi Stru Problem and add Port to HbFTP
latest Version v1.26
32 Bit
HBFM_126.zip
(2.19 MiB) Downloaded 251 times
64 Bit
HBFM64_126.zip
(2.51 MiB) Downloaded 227 times
have also update Source on Github
known Problem : when start HBFM64.EXE 1st time it take much time ... :roll:
does not happen with 32 BIT App
Re: NC Clone
Hi jimmy :
remembering the use of HBTIP since I did Email examples I had checked the tUrl class that returns an oUrl object, this class receives a cUrl text containing the following fields
this kind of returns to itself
METHOD New( cUrl ) CLASS TUrl
   ::SetAddress( cUrl )
   RETURN Self
This object can return incorrect as indicated here, it can behave well with domains such as example.org but wrongly before IP addresses like 192.168.1.39
study tUrl class
METHOD SetAddress( cUrl ) CLASS TUrl
LOCAL aMatch, cServer, cPath
   IF ! HB_ISSTRING( cUrl )
      RETURN .F.
   ::cAddress  := cUrl
   ::cProto    := ""
   ::cUserid   := ""
   ::cPassword := ""
   ::cServer   := ""
   ::cPath     := ""
   ::cQuery    := ""
   ::cFile     := ""
   ::nPort     := -1
   IF cUrl == ""
      RETURN .T.
   // Top-level URL parsing. May fail.         <----- HERE
   IF Empty( aMatch := hb_regex( ::cREuri, cUrl ) )
      RETURN .F.
   ::cProto := Lower( aMatch[ 2 ] )
   cServer  := aMatch[ 3 ]
   cPath    := aMatch[ 4 ]
   ::cQuery := aMatch[ 5 ]
   // server parsing (never fails)
   aMatch      := hb_regex( ::cREServ, cServer )
   ::cUserId   := aMatch[ 2 ]
   ::cPassword := aMatch[ 3 ]
   ::cServer   := aMatch[ 4 ]
   ::nPort     := Val( aMatch[ 5 ] )
   IF ::nPort < 1
      ::nPort := -1
   // Parse path and file (never fails)
   aMatch := hb_regex( ::cREFile, cPath )
   ::cPath := aMatch[ 2 ]
   ::cFile := aMatch[ 3 ]
   RETURN .T.
METHOD BuildAddress() CLASS TUrl
   LOCAL cRet := ""
   IF ::cProto != NIL
      ::cProto := Lower( ::cProto )
   IF ! Empty( ::cProto ) .AND. ! ::cServer == ""
      cRet := ::cProto + "://"
   IF ! ::cUserid == ""
      cRet += ::cUserid
      IF ! ::cPassword == ""
         cRet += ":" + ::cPassword
      cRet += "@"
   IF ! ::cServer == ""
      cRet += ::cServer
      IF ::nPort > 0
         cRet += ":" + hb_ntos( ::nPort )
   IF ::cPath == "" .OR. ! Right( ::cPath, 1 ) == "/"
      ::cPath += "/"
   cRet += ::cPath + ::cFile
   IF ! ::cQuery == ""
      cRet += "?" + ::cQuery
   RETURN iif( cRet == "", NIL, ::cAddress := cRet )
It is a mistake to create an object and then send it to build another object without the proper consistency.
   oUrl := tURL() :New( cUrl )
   IF EMPTY( oUrl )
      RETURN nil
   oClient := TIpClientFtp() :new( oUrl, Sites->Log )                 // PARAM .T. TO LOG
   IF EMPTY( oClient )
      RETURN nil
   oClient:nConnTimeout := 2000
   oClient:bUsePasv     := .T.
I suggest you try the following code to eliminate that IP address or domain error
STATIC FUNCTION ftpConnect()
LOCAL bError    := ERRORBLOCK( { | oErr | BREAK( oErr ) } )
LOCAL lConnect  := .F.
LOCAL cUser     := sites->user
LOCAL cPassWord := desencri( sites->password )
LOCAL cServer   := sites->address
LOCAL cUrl
   cUrl := "ftp://" + ALLTRIM( cUser ) + ":" + ALLTRIM( cPassWord ) + "@" + ALLTRIM( cServer )
   IF EMPTY( oUrl )
      RETURN nil
   oUrl:cProto    := "ftp://"
   oUrl:cServer   := cServer
   oUrl:cUserId   := sites->user
   oUrl:cPassword := adesencri( sites->password )
   oUrl:nPort     := sites->port                                      // Numeric
     BEGIN SEQUENCE
	 RECOVER
            MsgBox('can not Open() the connection, try again ' , 'Attention message' )
            Return nil
      END
Re: NC Clone
danielmaximiliano wrote: Thu Sep 10, 2020 2:41 am I suggest you try the following code to eliminate that IP address or domain error
   IF EMPTY( oUrl )
      RETURN nil
     BEGIN SEQUENCE
	 RECOVER
            Return nil
      END
it is a good Idea using BEGIN SEQUENCE :!:
i have try that Code but end up in RECOVER :o
so i reduce it to
   IF !EMPTY( nPort )
      oURL:nPort := nPort
and now i got Connect again :D
hm ... perhaps i need to fill default Value to 21 as you say.
Re: NC Clone
latest Version v1.27
32 Bit
HBFM_127.zip
(2.19 MiB) Downloaded 236 times
64 Bit
HBFM64_127.zip
(2.51 MiB) Downloaded 235 times
fixed :
fixed Thumbs ImageRelease "SlideTime"
fixed SumatraPDF Filename with Space
new :
HbFTP : default Port := 21
Re: NC Clone
AUGE_OHR wrote: Wed Aug 26, 2020 8:54 pm
! Note : Source Code is avaiable under https://github.com/AugeOhr/HBFM
(no Image include in Source)
Hi Jimmy: download from the NC clone version, I could recover the \RES folder and compile, I would need the 32 and 64 bit libs that it uses and in that way to be able to correctly execute NC clone, in that way to be able to modify the FTP option of the Same.
From already thank you very much
Re: NC Clone
danielmaximiliano wrote: Tue Sep 22, 2020 1:21 am Hi Jimmy: download from the NC clone version, I could recover the \RES folder and compile, I would need the 32 and 64 bit libs that it uses and in that way to be able to correctly execute NC clone, in that way to be able to modify the FTP option of the Same.
64 Bit DLL / Lib of FreeImage is found in this Thread.
http://www.hmgforum.com/viewtopic.php?f ... 7&start=23
Code for Libxlsxwriter is still include but as i´m not able to generate 64 Bit DLL / LIB it is not active
ADO must be installed as ActiveX but have no LIB to include
what do you want to modify :?: SFTP ... :idea:
Re: NC Clone
Hi Jimmy:
As we see after general the Url when trying to connect the application remains frozen for a while until it gives an error since the URL is wrong .. that occurs when using IP addresses type B or C
LOCAL bError
LOCAL nPort     := sites->Port
LOCAL cUrl, oError
   cUrl := "ftp://" + ALLTRIM( cUser ) + ":" + ALLTRIM( cPassWord ) + "@" + ALLTRIM( cServer ) + STR ( nPort )
   IF EMPTY( oUrl )
      RETURN nil
	   msgbox( oUrl:cAddress,"Entro"  )
2020-09-22 17_02_55-FTP Client v0.1.0 modify for HMG.png (32.46 KiB) Viewed 11471 times
Re: NC Clone
danielmaximiliano wrote: Tue Sep 22, 2020 8:07 pm As we see after general the Url when trying to connect the application remains frozen for a while until it gives an error since the URL is wrong .. that occurs when using IP addresses type B or C
i have add Port in v1.26
please get latest Source from GitHub and look into HBFTP.PRG if it work for you
i just have test it with Port 21
Re: NC Clone
AUGE_OHR wrote: Tue Sep 22, 2020 8:36 pm i have add Port in v1.26
Hi Jimmy, the port addition in FTP applications is to place the service on another port than the default one. as being Android that its FTP service is port 21; in this case, any other app cannot use port 21 as it is busy. that's why File Manager uses another one manually, in my case the 8556
HBtip by default assumes port 21 for FTP services that you can check in C:\Harbour\contrib\hbtip\ftpcli.prg
METHOD New( oUrl, xTrace, oCredentials ) CLASS TIPClientFTP
   ::super:new( oUrl, iif( hb_defaultValue( xTrace, .F. ), "ftp", xTrace ), oCredentials )
   ::nDefaultPort := 21
   ::nConnTimeout := 3000
   ::nAccessMode  := TIP_RW  // a read-write protocol
   ::nDefaultSndBuffSize := ::nDefaultRcvBuffSize := 65536
   // precompilation of regex for better prestations
   ::RegBytes := hb_regexComp( "\(([0-9]+)[ )a-zA-Z]" )
   ::RegPasv  := hb_regexComp( "([0-9]*) *, *([0-9]*) *, *([0-9]*) *, *([0-9]*) *, *([0-9]*) *, *([0-9]*)" )
   RETURN Self
If you look inside the example you will see C:\Harbour\contrib\hbtip\tests\*.*
that the port is never added, in case the port is different, it should be able to change in the case that I requested for NC clone.
I am going to review this inconvenience that is within HBTIP to set up an IP address correctly in case of being internal class C networks such as 192.168.1.1
Re: NC Clone
it seem there is a big BUG in HBFM since v1.17 :shock:
after delete a File HBFM does not work correct with F3/F4 and show "black" Window or "no Image" etc. :evil:
