prg code function documentor in HMG
HGAutomator wrote: Thu Apr 22, 2021 2:05 am But I only see the PRGs. Which Zip file is the hbp file in?
sorry, last Files CLICK20535.ZIP and hb_CLICK_20534.ZIP only include *.PRG
use hb_CLICK_20529.ZIP which include *.HBP and override with hb_CLICK_20534.ZIP and last CLICK20535.ZIP
HGAutomator
Post by HGAutomator »
Ah, ok. I'll find those, thanks Auge.
Anand
Post by Anand »
HGAutomator wrote: Thu Apr 22, 2021 5:21 pm Ah, ok. I'll find those, thanks Auge.
Here it is,
viewtopic.php?p=60711#p60711
Hope it helps :)
Anand
Anand
HGAutomator
Got it, thanks Anand.
a small Util for CLICK which produce "Src_cros.TXT"
i most i "test" a Modul before integrate to Main.
so i have a lot of STATIC PROC / FUNC in my Source Code.
DUPEFUNC will "read" Src_cros.TXT and give you "dupe" Func / Proc Name
DUPEFUNC.ZIP
(600 Bytes) Downloaded 355 times
when try CLICK with
DEFINE REPORT
i got Problem ... so i add
LAYOUT
HEADER
LINE
TEXT
DETAIL
FOOTER
SUMMARY
GROUP
GROUPHEADER
GROUPFOOTER
now i can "CLICK" Sample \SAMPLES\Controls\ReportAdvanced\REPORT_ADVANCED_XXX
please report if you have "more" Problem with Controls which i have not used yet (so not test by CLICK)
todo :
FOR EACH
SWITCH
have fun with new Source v2.05.39
CLICK20539.ZIP
only CLICK.PRG as Update !
(26.65 KiB) Downloaded 376 times
emzampi
Post by emzampi »
Hi AUGE_OHR I really appreciated your work with hb_click and seen the different versions you made I would like to have if possible the latest working and compilable version of your wonderful program thank you very much for what you have done.
there was no bit change sind 2.05.39
i have fix BUG with Button "Source" / "DBF" to assign TEXTBOX in 2.05.40
here FULL Source Code
CLICK20540.ZIP
(71.29 KiB) Downloaded 423 times
todo:
FOR EACH
TRY / CATCH
emzampi
Post by emzampi »
Hello and thanks for the availability, but I see that I have problems compiling it (version 20.05.27 worked) I send you the text of error.log to see if you can understand what is not working ..... thanks again
emzampi
Post by emzampi »
I realized this ICON RES \ CLICKBW32.ico is missing ..... I created a folder and inserted an .ico file and it works ....
you forgot to insert the original .ico file and sorry if I dare but on the click.rc file the version indicated is 38 and not 40 and also the recent hmg version is 3.5 while on the click.rn file 2 ICON c is indicated: \ hmg.3.4.4 \ DOC \ assets \ img \ HMG-UNICODE_icon.ico
sorry if I allowed myself but thank you very much for the work you have done which is very useful
