HMG 3.4.4
Re: HMG 3.4.4
A download error in HMG 3.4.4: :(
Re: HMG 3.4.4
Thank you Esgici. Now rectified.
Re: HMG 3.4.4
Rathinagiri wrote: Tue Jan 09, 2018 5:17 pm Thank you Esgici. Now rectified.
Thanks.
Viva HMG :D
ROBROS
Re: HMG 3.4.4
Post by ROBROS »
Hi all,
I intend to go 64 bits. What has to be considered? Are there suggested folders? Of course I will keep my actual installation. Any advice is appreciated.
Best regards
Robert
asharpham
Re: HMG 3.4.4
Post by asharpham »
What is the difference between hmg.3.4.4 & hmg-18.03-setup.exe?
Re: HMG 3.4.4
Hello, Robert: (ROBROS)
Very easy first download in:
viewtopic.php?f=43&t=5198
You can download this latest version from ----> here <------- (64 MB)
https://drive.google.com/open?id=0B668x ... 2dOWG9yQTA
Install the package, in my case I have it installed in c:\hmg.3.4.4_64
After download
You can download this latest version from here (64 MB)
For 64 Bit developers, you have to download and install Harbour64 and MingW64 from here (15 MB) and here (71 MB) respectively.
https://drive.google.com/open?id=0B3L0Q ... zZ3bDd3cU0
https://drive.google.com/open?id=0B3L0Q ... TdnUmVUeEU
then unpack inside c:\hmg.3.4.4_64
HARBOR-64 and MinGW-64
inside folder executes _BuildAllLib64.bat 1 for ANSI and 2 for UNCOCE
then you make a Bat file like the one I put on you
which has to be where is your main application example Main.prg
build.3.4.4_64.bat
@ECHO OFF
call c:\hmg.3.4.4_64\build64.bat Main.prg % *
and I already think that it will work
viewtopic.php?f=46&t=5479&p=53563&hilit=64+bits#p53563
I do not know if the LIB-64 folder is missing in the insytalación?
Sorry that no English
Re: HMG 3.4.4
asharpham wrote: Wed Mar 28, 2018 12:03 pm What is the difference between hmg.3.4.4 & hmg-18.03-setup.exe?
Please be so kind to take a look for
viewtopic.php?f=5&t=219&p=1319
asharpham
Re: HMG 3.4.4
Post by asharpham »
Ah thank you, Grigory. I did a search initially but couldn't find this. After checking it out I think I'll stick with good old HMG! My skillset struggles as it is without going any deeper.
Alan
ROBROS
Re: HMG 3.4.4
Post by ROBROS »
Hi Mustafa,
thx for your reply, I will try this during the easter holidays.
Your English is good enough to understand what you are writing.
Regards from Bavaria.
Robert
nikko1960
Re: HMG 3.4.4
Post by nikko1960 »
Hi to all
I'm new to hmg, and yesterday i'have downloaded the 3.4.4 32 bit version.
The Os is Windows 10 pro 32 bit
run buildalllib32 and works
IDE is working fine, i have created for our company a little prototype.
When i try to compile, no executable is generated.
this is the error reported
hbmk2: Link in corso di... pagodil.exe
c:/hmg_344/mingw/bin/../lib/gcc/i686-w64-mingw32/5.3.0/../../../../i686-w64-mingw32/bin/ld.exe: cannot find -lmysql
hbmk2[pagodil]: Errore: nell'esecuzione del linker. 1
gcc.exe .hbmk/win/mingw/Main.o .hbmk/win/mingw/_hbmkaut_Main.o D:/pagodil/_temp.o -pthread -static-libgcc -static-libstdc++ -static -lpthread -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbmysql -lmysql -lhbfimage -lhbpgsql -lsddmy -lhbvpdf -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -opagodil.exe -Lc:/hmg_344/harbour/lib/win/mingw -Lc:/hmg_344/lib
my thougth
why mingw need mysql lib if i do not use it ?
what i'm doing wrong ?
are there some search path that i have not included ?
Domenico
