HMG 3.4.1
Re: HMG 3.4.1
Thanks for the update Claudio !
Re: HMG 3.4.1
Thanks Docsrvet_claudio wrote:
1) please unzip this patch in folder c:\hmg.3.4.1
2) and rebuild the lib
Re: HMG 3.4.1
Thank Roberto lopez andDr Claudio Soto for your shared
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
Re: HMG 3.4.1
FYI:
- Two link named "Patch" in this post (probably added later) are not real patch; they are superseded by Patch-1 sent by Dr. Soto.
- File name in the given download URL is : HMG.3.4.1.Setup_old.exeRathinagiri wrote:
I am so happy to announce about the new version of HMG 3.4.1, thanks to Dr. Claudio Soto.
This time HMG is released in Google Drive. Please let me know if you have any difficulty in downloading. This version can be downloaded from here. (81.3MB)
Remarks:
[/color]
- dhaine_adp
- srvet_claudio
Re: HMG 3.4.1
Yes you are right.mol wrote:I found error in GRID control while using CHECKBOX in COLUMNCONTROLS.
GRID.CELL(nCheckBoxKolumnIndex) always return .f.
Try this sample produces from GRID_09:I've not tested with hmg 3.4.1 (i had no time to install itCode: Select all
/* * HMG Grid Demo * Please try this sample to test CELL property and ITEM property */ #include "hmg.ch" Function Main Local aRows:= array(1) DEFINE WINDOW Form_1 ; AT 0,0 ; WIDTH 640 ; HEIGHT 400 ; TITLE 'GRID ERROR TEST' ; MAIN DEFINE MAIN MENU DEFINE POPUP 'File' MENUITEM 'Get Item' ACTION GetItem() END POPUP END MENU aRows [1] := {113.12, date(), 2, 3, .t. } @ 10,10 GRID Grid_1 ; WIDTH 620 ; HEIGHT 330 ; HEADERS {'Column 1','Column 2','Column 3','Column 4','Column 5'} ; WIDTHS {100,100,100,140,100} ; ITEMS aRows ; EDIT ON CHANGE playbeep() ; COLUMNCONTROLS { {'TEXTBOX','NUMERIC','$ 999,999.99'} , {'DATEPICKER','DROPDOWN'} , {'COMBOBOX',{'One','Two','Three'}} , { 'SPINNER' , 1 , 20 } , { 'CHECKBOX' , 'Yes' , 'No' } } ; CELLNAVIGATION END WINDOW CENTER WINDOW Form_1 ACTIVATE WINDOW Form_1 Return PROCEDURE GETITEM() local a local n n := 1 aItem := Form_1.Grid_1.Item (n) aCells := { Form_1.Grid_1.Cell(1,1),; Form_1.Grid_1.Cell(1,2),; Form_1.Grid_1.Cell(1,3),; Form_1.Grid_1.Cell(1,4),; Form_1.Grid_1.Cell(1,5) } msgdebug("this is array built with Grid_1.CELL(i) property", aCells) msgdebug("this is Grid_1.ITEM property", aItem, " and 5'th column:", aItem[5]) RETURN), I think the result will be the same.
Please test it.
I fixed.
Re: HMG 3.4.1
THX for quick reactionClaudio wrote: Yes you are right.
I fixed
jorge.posadas
Re: HMG 3.4.1
HMG,
I already download the HMG 3.4.1 verion but when I try to user DEMO.BAT in this path C:\hmg.3.4.1\SAMPLES\HFCL\SQL\SQLITE
I get this errorr
Harbour 3.2.0dev (r1506261250)
C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_zkvm1n.dir/demo.o:demo.c:(.data+0xa8): undefined reference to `HB_FUN_CONNECT2DB'
C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_zkvm1n.dir/demo.o:demo.c:(.data+0x178): undefined reference to `HB_FUN_SQL'
C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_zkvm1n.dir/demo.o:demo.c:(.data+0xe8): undefined reference to `HB_FUN_C2SQL'
C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_zkvm1n.dir/demo.o:demo.c:(.data+0x188): undefined reference to `HB_FUN_MISCSQL'
C:/hmg.3.4.1/mingw/bin/../lib/gcc/i686-w64-mingw32/4.9.2/../../../../i686-w64-mingw32/bin/ld.exe: C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_zkvm1n.dir/demo.o: bad reloc address 0xf in section `.text.startup'
C:/hmg.3.4.1/mingw/bin/../lib/gcc/i686-w64-mingw32/4.9.2/../../../../i686-w64-mingw32/bin/ld.exe: final link failed: Invalid operation
hbmk2: Error: Ejecutando enlazador. 1
gcc.exe C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_zkvm1n.dir/demo.o C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_zkvm1n.dir/hbmk_rnti86.o C:/hmg.3.4.1/SAMPLES/HFCL/SQL/SQLITE/_temp.o -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lxhb -lpng -llibhpdf -lhbvpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -odemo.exe -LC:/hmg.3.4.1/harbour/lib/win/mingw -LC:/hmg.3.4.1/lib
hbmk2: Error: Funci¢n(es) referenciada, no encontrada, pero desconocida:
PD I download the path "hmg.3.4.1_patch1.rar" and then run the "BuildAllLib" but I get the same error.
I have W8, 64bits
I get this errorr
I have W8, 64bits
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
POSADAS SOFTWARE
Jorge Posadas Ch.
Morelia, Mich.
M é x i c o .
Re: HMG 3.4.1
OLá amigos
Fiz o upgrade da versão 3.3.1 para a versão 3.4.1, entretanto o controle RichEditBox parou de funcionar. Isto pode ser verificado no sample em \Samples\controls\RichEditBox ou inserindo um controle RichEditBox em um projeto na IDE. Suspeito que o problema tenha relação com a propriedade "INVISIBLE" do controle.
Parabéns pelo ótimo trabalho
Abraços
André
Hello friends
I upgraded from version 3.3.1 to version 3.4.1 , but RichEditBox control stopped working. This can be seen in the sample in \Samples\controls\RichEditBox\ or by inserting a RichEditBox control in a project in the IDE. I suspect that the problem is related to the "INVISIBLE" property of the control.
Congratulations for the great work
Best regards
André
Hola amigos
He actualizado desde la versión 3.3.1 a la versión 3.4.1 , pero el control RichEditBox dejó de funcionar. Esto se puede ver en la muestra en \Samples\Controls\ RichEditBox\ o mediante la introducción de un control RichEditBox en un proyecto en el IDE. Sospecho que el problema está relacionado con la propiedad "INVISIBLE" del control.
Felicitaciones por el gran trabajo
saludos
André
Abraços
André
Hello friends
Best regards
André
Hola amigos
saludos
André
