HFCL (Hmg Forum Component Library)
Source code related resources
fchirico
Re: HFCL (Hmg Forum Component Library)
Post by fchirico »
rathinagiri wrote:Here is a new bug fixed, enhanced version of HFCL 0.92a. (2009.06.17)
hfcl.0.92a.zip
Change Log:
GridPrint
Thank rathinagiri!!!
Saludos, Fernando Chirico.
Vanguarda
Post by Vanguarda »
hfcl.0.92a.zip
Change Log:
GridPrint
1. Fixed: Show window command error
2. Fixed: When columns are summed up, column width is not calculated according to the total. Now, total is within the column width.
3. Changed: When column sum is used, number mask passed on is used for the whole column to be printed to make the column look uniform.
4. New: "Reset Form" button is added to reset the report configuration saved in the config file "reports.cfg".
Thanks Rathi for this release.
with best regards,
I've made a little UCI sample.
It allows to use HFCL ComboSearchBox control in IDE.
Enjoy!
ucisample.rar
(2.62 KiB) Downloaded 868 times
Thank you Roberto. I will try.
Roberto Lopez wrote:Hi All,
Enjoy!
Hello Roberto,
It runs fine. :)
Thanks a lot.
Do you have any plan to include ComboSearchBox control in next version of IDE? We are waiting for this :)
It is so easy! Thanks a lot Roberto.
Enjoy!
Hello Roberto,
It runs fine. :)
Thanks a lot.
IMHO, .uci is a perfect method of adding user control interfaces to HMG-IDE.
Hello Rathi,
rathinagiri wrote: IMHO, .uci is a perfect method of adding user control interfaces to HMG-IDE.
Thank you very much. I didn't know it. I learned it from you :)
I have very limited knowledge on IDE (and HMG also).
But, when I try to make some changes with the Hello.fmg form with IDE, most of the codes for CSB vanished. Moreover, when I select CSB control in the form (in ide), I found no property/method in property window.
May be I did something wrong. Can you please help me in this case?
TIA.
sudip wrote:It runs fine. :)
Thanks a lot.
Its already done!!! :)
The way to add an user component to IDE is the creation of a '.uci' file containing properties and events for that control.
'combosearchbox.uci' is included in the attachment.
Thanks a lot.
Thanks a lot Master Roberto. I am not sure where I did wrong, but when I try to change form, most of the properties of ComboSearchBox control are vanished. Moreover I cannot see any property/method in the property window when I select ComboSearchBox control.
I want to learn where I am doing mistakes.
Thank you very much again for ComboSearchBox.uci.
