Welcome to the Project Developers' Table
Re: Welcome to the Project Developers' Table
Thanks a lot for the answer Francesco.
So, with the updated version of Harbour & HBQT (built with 02-11-2010 nightly source of Harbour 15729), shall I try to reinstate :disconnect()?
Even now, with the new version, if we disconnect an unconnected event, it gives out the following error.
Error HBQT/1299 Argument error
Called from __HBQT_ERROR( 0 )
Called from QLINEEDIT:DISCONNECT( 0 )
Called from TEXTBOX:CREATE( 553 )
Called from WINDOW:CREATEPENDINGCHILDCONTROLS( 1336 )
Called from WINDOW:ACTIVATE( 1531 )
Called from MAIN( 175 )
2010-11-04 10:55 UTC+0530 Rathinagiri ( srgiri@dataone.in )
* source/browse.prg
* source/checkbox.prg
* source/checkbutton.prg
* source/combobox.prg
* source/control.prg
* source/datepicker.prg
* source/editbox.prg
* source/grid.prg
* source/ipaddress.prg
* source/listbox.prg
* source/menuitem.prg
* source/monthcalendar.prg
* source/printer.prg
* source/radiogroup.prg
* source/slider.prg
* source/spinner.prg
* source/tab.prg
* source/textbox.prg
* source/tree.prg
* source/window.prg
* Code changed to meet current HBQT version. :disconnect() event is now checked for whether the event is already connected.
* samples/textbox/demo_4.prg
! Fixed a small bug.
* source/browse.prg
* source/grid.prg
* source/slider.prg
* source/tab.prg
* source/tree.prg
* source/window.prg
I've done some more work on ABM2 and I think I've found some points I want to discuss with you.
It seems to me that all HMG windows are implemented with QMainWindow Qt object. I ask you to open at assistant and search for QMainWindow class and scroll down to the nice graph.
QMainWindow has several areas it may divided into. They are not mandatory, you can have or not have them, but if you use them your work is made more easy.
In Qt, for example, toolbars are moveable, you can put them at top, bottom, left and right. If you have a tool bar but don't include the objects in the form in a QWidget and assign it to the central widget position, it happens that the moving toolbar can overwrite the form objects. There may also be problems for input focus... and you need to add the toolbar height to objects row to not overwrite the toolbar at the top, but when moving it to another position that empty space is not nice to see. I experimented all these during ABM2 conversion...
The solution is to add the hmg objects of the form to a QWidget and then set that QWidget as the central widget of QMainWindow. IN this case QT will take care of all movements.
QWidget acts as a container of a group of objects, and this is already used in hmg TAB, to hold all the objects of a tab page.
How can we add a hmg object to a QWidget ?
As first step we need a QWidget object, so I created a hmg Widget class, whose only method is Create() and this is turn creates a QWidget.
Then I tried to use :parent to specify the container but it didn't work because in conflict with TAB.
Browsing the code I saw that all Create() class use this kind of code:
and decided to set oContainer in my code to specify the container, and it worked.
As you know, Qt objects are created only at window:Activate() and so at the moment we must do all the dirty job in the on init function. In this function we assign the toolbar and the widget at the window and Qt will take care of everything.
Why did I explain all this ? Various reasons
1) do you want me to commit these changes ? at the moment they don't touch any core code, there is just one class and everything must be done in "user-code"
2) I'd like to have some more Qt features integrated in hmg and this can be done only after a discussion on what and how to implement the features, they may have side-effects
3) from my tests, using :parent interferes with TAB, it would be nice to better defines this, or better make :parent generic
4) what about adding layouts to hmg ? Docks ?
Would you like to create different threads for these topics ? Read the message in this more explicit way: are you willing to discuss and - perhaps - change some inner code of hmg ?
IF valtype( ::oContainer ) == 'U'
::oQTObject := QLabel( ::oParent:oQTObject )
::oQTObject := QLabel( ::oContainer:oQTObject )
IMHO, the main objects of HMG4 are, simplicity and backward compatibility. If these are not affected, yes we can change the inner code.
I want to know what are the changes in 'user-code'.
Please commit the changes and let us know about the difference...
Hi Rathinagiri, I just committed the code.rathinagiri wrote:Please commit the changes and let us know about the difference...
2010-11-05 10:55 UTC-0300 Francesco Perillo (<fperillo@gmail.com>)
* source/widget.prg
* Implemented WIDGET class, the equivalent of QWidget.
* samples/widget/demo_3a.prg
* sample to show what happens when relocating toolbar without using WIDGET
* samples/widget/demo_3b.prg
* sample to show what happens when relocating toolbar using WIDGET and
how to assign the central widget at runtime
I did not implemented WIDGET class in hmg.ch... I never did that kind of job and I may create errors, so I ask you to take care of it.
In two words: define a Widget and assign all the objects to it:
myWidget1 := Widget():New()
With Object l1 := Label():New()
:Name := "l1"
:parent := myWidget1
:Value := "this is myWidget1"
myWidget1:CentralWidgetOf := oWindow
Actually, in TABPAGE a QWidget is defined (as it should be) to be the container of all the objects in that page. I think that the QWidget usage should be changed to hmg widget. I say this because Widget should be the basic building block of every form, and on top of widget it is possible to create different interesting layouts !
In hmg.ch there are some places where length is mispelled:
- [ MAXLENGTH <nMaxLenght> ]
+ [ MAXLENGTH <nMaxLength> ]
- [:MaxLenght := <nMaxLenght> ]
+ [:MaxLength := <nMaxLength> ]
and of course also the class methods names should be changed...
Sorry Rathinagiri,
browsing the code today I found this change in control:OnLostFocus:
Disconnecting a non existant event gives a RTE ? It shouldn't! If it does please check with a more recent version of hbqt.
Perhaps we should think about adding [dis]connect methods to class CONTROL
In the next method, OnClick:
so it seems that it's ok to disconnect a not-connected signal...
IF .NOT. ::oQTObject:connect( QEvent_FocusOut , ::bOnLostFocus )
::oQTObject:disconnect( QEvent_FocusOut )
// Can't connect the event... error
::bOnClick := bValue
::oQTObject:DisConnect( "clicked()" )
::oQTObject:Connect( "clicked()" , ::bOnClick )
Last message for today, I promise
see this code:
I propose some changes (code not tested, it's just a proposal)
A bit of code refactoring, a bit of parameter checking, a bit of error reporting.... just an idea....
see this code:
METHOD OnClick( bValue ) CLASS CONTROL
IF ::lCreated
IF Pcount() == 0
RETURN ::bOnClick
ELSEIF Pcount() == 1
*::oQTObject:DisConnect( "clicked()" )
IF pcount() == 0
RETURN ::bOnClick
ELSEIF pcount() == 1
// one code for both ::lCreated values
IF Pcount() > 1
// error
::bOnClick := NIL
IF HB_isBlock( bValue ) // check parameter type to avoid chaos
// Generate error and/or
::bOnClick := NIL // must remove old codeblock
return NIL
IF ::lCreated .and. hb_isblock( ::bOnClick )
// force disconnect, ignore return value
// connect
if ! ::oQTObject:Connect( "clicked()" , ::bOnClick )
// generate error (some errors already generated by :connect,
// if it returns .F. after a :disconnect there may be other problems...
::bOnClick := NIL
ENDIF //::lCreated
RETURN ::bOnClick
After a festival holiday and a small tour, I had just now returned and seen your posts. I try to understand what happens with Widget class.
Unconnected signals are not giving RTE.
Yes. Disconnecting a non existent event gives a RTE. Can you tell me which version you are using? I am using Release 15729.Disconnecting a non existant event gives a RTE ? It shouldn't! If it does please check with a more recent version of hbqt.
Yes, that is a nice idea. However, some signals/events are widget specific and on change of one widget is different from on change of another widget.Perhaps we should think about adding [dis]connect methods to class CONTROL
