prg code function documentor in HMG
RPC
Post by RPC »
Hi Jimmy
I got confused, your DP mentions it as AUGE_OHR so I was addressing you accordingly.
Henceforth I will call you Jimmy.
Yes I got a different icon instead of your icon.
I think the second icon is redundant, it doesn't seem to be used anywhere.
this is the Clipper Source to get IndexKey() from NTX without load DBF.
INDDUMP.ZIP
(3.76 KiB) Downloaded 836 times
it use low level and read at byte 22
i have made some test and it seem still work after 20 year :D
i do have a Problem with HMG Source Syntax and Logic of CLICK
c:\hmg.3.4.4\SOURCE\H_GRID.PRG
1017 IF AEC = 'EDITBOX'
      DEFINE WINDOW _HMG_GRID_InplaceEdit AT 0, 0 ;
                 WIDTH 350 ;
                 HEIGHT 350 + IF( IsAppThemed(), 3, 0 ) ;
                 TITLE _HMG_SYSDATA[ 7 ] [ idx ] [ ci ] ;
                 MODAL ;
                 NOSIZE ;
                 SHORTTITLEBAR
         DEFINE WINDOW _HMG_GRID_InplaceEdit AT r + DR, c + DC ;
                    WIDTH This.CellWidth + DW ;
                    HEIGHT This.CellHeight + 6 + DH ;
                    TITLE '' ;
                    MODAL NOSIZE NOCAPTION
c:\hmg.3.4.4\SOURCE\h_controlmisc.prg
3437 IF nR + nH > GetDeskTopRealHeight()
      nDiff := nR + nH - GetDeskTopRealHeight()
      // nR := nR - nDiff
      DEFINE WINDOW _InputWindow AT nR, nC WIDTH nW HEIGHT( nH - nDiff ) ;
                 VIRTUAL HEIGHT nH VIRTUAL WIDTH nW + 20 ;
                 TITLE cTitle MODAL NOSIZE BackColor aBackColor ON RELEASE _InputWindowOnRelease(OldScrollStep, aHotKeys )
         SET SCROLLSTEP TO 20
         DEFINE WINDOW _InputWindow AT nR, nC WIDTH nW HEIGHT nH ;
                 TITLE cTitle MODAL NOSIZE BackColor aBackColor ON RELEASE _InputWindowOnRelease( OldScrollStep, aHotKeys )
there is a DEFINE but no ENDxxx before ELSE or ENDIF ... hm
so i have change 2 lines in CLICK
NOT to use "DEFINE WINDOW" to indent
search for "Jimmy 20200921" in new CLICK.PRG
here changed Code
--- deleted ---
here working full Source Code (only PRG) v2.05.34
hb_CLICK_20534.ZIP
(64.7 KiB) Downloaded 868 times
p.s.
when work with c:\hmg.3.4.4\SOURCE\*.PRG (no Subfolder) it need some small modification.
i will open extra Thread
Modification in v2.05.34 for HMG \Source work but it look not nice with "normal" Syntax.
So I add option in CLICK whether to indent DEFINE WINDOW or not
Upgrade is just CLICK.PRG so you need last full Version.
CLICK20535.ZIP
(26 KiB) Downloaded 918 times
latest CLICK Version 2.05.36
CLICK20536.ZIP
(26.14 KiB) Downloaded 655 times
add "NODE" for DEFINE TREE like this
   DEFINE TREE Tree_1 ...
      NODE 'Item 1'
         TREEITEM 'Item 1.1'
         TREEITEM 'Item 1.2' ID 999
         TREEITEM 'Item 1.3'
      END NODE
jairpinho
Post by jairpinho »
AUGE_OHR wrote: Mon Nov 16, 2020 1:15 am latest CLICK Version 2.05.36
CLICK20536.ZIP
      NODE 'Item 1'
         TREEITEM 'Item 1.1'
         TREEITEM 'Item 1.3'
      END NODE
hello Jimmy can compile with HMG ide
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
jairpinho wrote: Mon Nov 16, 2020 2:29 am hello Jimmy can compile with HMG ide
HGAutomator
Post by HGAutomator »
Wow. I remember CLICK, I didn't know someone built a harbour version. Thanks.
I have all the sources. Do we build it with hbmk2.bat?
HGAutomator wrote: Sat Apr 17, 2021 2:41 am I have all the sources. Do we build it with hbmk2.bat?
i have include *.HBP so you can use
build CLICK.HBP
HGAutomator
Thanks Auge,
But I only see the PRGs. Which Zip file is the hbp file in?
Should I just throw in the full list CLICK files, CLICK,XBASE,FUNCTRAK, etc. into a CLICK.HBP?
