Ready for next version?
Re: Ready for next version?
Hif friend Rathi:
I'm glad to read you again.-
I agree to enter on the discussion of this topic.-
Although i feel very confortly with last version of HMG, reason why, i think that there are not to much to upgrade, just apply all HMG power to our app, any proposal everyone make must be without comparission with profesional and high cost developer tools.-
As you i don't know anything about C, that means a great limitation.- But without that limitation i develope several app that simulates screens functionality and themes seen on libreries like BCG.- They are not equal, but finally works without issues.-
Said this, i suggest that any proposal, need to show that is possible to include on a new upgrade. Otherwise is a lack of time and effort.-
With regards.
Eduardo
With regards.
Eduardo
Hmg 344 is very stable.
We should work with new IDE and some enhances in Claudio debugger
All examples should work out of box.
Add more examples as many new samples contributed by members in this forum.
Anand
Anand
- mustafa
Hola amigo Rathinagiri
Sobre los Nuevos Post de este Foro , tanto como los nuevos Samples
como las intervenciones de los compañeros , cuando están en la
Zona ---> NEW POSTS , están muy poco tiempo Visible en esta zona de la
Web , no se si es un proceso automatico ?
Rápidamente pasan a la zona ---> RECIENT TOPICS
Mi pregunta es ? en la zona NEW POSTS podrían estar por la menos un día ?
Con Respeto, Saludos
*----------------------------------- Google --------------------------------*
Hello friend Rathinagiri
About the New Posts of this Forum, as well as the new Samples
as the interventions of colleagues, when they are in the
Zone ---> NEW POSTS, they are very little time Visible in this area of the
Web, do not know if it's an automatic process?
Quickly move to the area ---> RECENT TOPICS
My question is ? in the area NEW POSTS could be at least a day?
With Respect, Greetings
New posts are visible until you read them
Who knows, it is possiblePeteWG wrote: ↑Wed Mar 13, 2019 7:30 amDidn't knew goddess Athena had helped Roberto Lopez in creating HMG!EduardoLuis wrote: ↑Tue Mar 12, 2019 6:16 pm Ancient Greeks had a saying : “Sin Athena kai hera kinei” which loosely translates into “Don’t expect everything from God, you have to act and he will aid you” (Quartz mention) +100
has done a miraculous work!
but is sure he was "waving his hands" !
Nikos.
os: Windows Server 2019 - 64
Nikos.
Hi Rathi! I'm glad to see you again!
Nikos.
Nikos.
- dragancesu
I think that version 3.4.4 is stable and does not need much change
In any case it can be improved, I see that there are constantly new members and users, it would be good to improve the documentation, and add examples
Maybe you need to add some utility programs
I see that minigui has a beautifier program, update code (ident) and facilitates reading the code and write references where the function is defined and where it is used
