PDF Viewer DLL?
Re: PDF Viewer DLL?
Impressive !
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
Edward
Check test versions PdfView_7 and PdfView_8.
Does LeftAlt work?
PdfView_test.zip
(11.69 KiB) Downloaded 351 times
Re: PDF Viewer DLL?
Page numbering at right bottom is flickering heavily (PdfViewTimer = 100) and viewing hmg-help.pdf shows (very) briefly the index
Re: PDF Viewer DLL?
Left-Alt does work (but a bit strange). Great Work !
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
Needed is a test on Windows-10, when focus is set in Sumatra panel.
serge_girard wrote: Sat Apr 01, 2017 4:08 pm Page numbering at right bottom is flickering heavily (PdfViewTimer = 100) and viewing hmg-help.pdf shows (very) briefly the index
Replace SetStatusPage() function with following code:
FUNCTION SetStatusPage()
  STATIC nPage   := 0
  STATIC nCount  := 0
  LOCAL  nPage1  := Sumatra_PageNumber(cPanel)
  LOCAL  nCount1 := Sumatra_PageCount(cPanel)
  IF (nPage != nPage1) .or. (nCount != nCount1)
    nPage  := nPage1
    nCount := nCount1
    PdfView.STATUSBAR.Item(2) := If(nCount == 0, "", "Page: " + HB_NtoS(nPage) + '/' + HB_NtoS(nCount))
Re: PDF Viewer DLL?
KDJ wrote: Sat Apr 01, 2017 2:24 pm Edward
Does LeftAlt work?
PdfView_test.zip
Krzysztof, alone LeftAlt work on focused Sumatra Panel, also first LeftAlt then "P" key, but not work LeftAlt-P pressed together (I can hear system sound).
Now LeftAlt key works just like F10.
The same symptoms on both versions: 7 and 8
As for me is Ok. Generally, I meant that the program did not hang up after accidentally pressing LeftAlt and/or F10.
Edward.
quartz565
Re: PDF Viewer DLL?
Post by quartz565 »
edk wrote: Sat Apr 01, 2017 8:19 pm
Does LeftAlt work?
PdfView_test.zip
Edward.
Same in windows 10 64 bit .
When the grid is focused all the keys and combinations works perfectly.
Nikos.
os: Windows Server 2019 - 64
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
Thank you very much gentelmen for testing the program.
Re: PDF Viewer DLL?
You're welcome, Krzysztof !
KDJ
Re: PDF Viewer DLL?
Post by KDJ »
New version of PdfView for HMG 3.4.4.
It doesn't work with earlier HMG versions.
PdfView.exe 32-bit:
PdfView_exe_32bit.zip
(1.47 MiB) Downloaded 404 times
SumatraPDF as library 32-bit:
SumatraPDF_lib_32bit.zip
(4.43 KiB) Downloaded 349 times
Source code:
PdfView_source.zip
(12.74 KiB) Downloaded 343 times
