HMG 3.4.1
Re: HMG 3.4.1
Claudio,
I've found a problem in InputWindow (this is an easy one :) )
If you do not specify a BackColor, instead of use the system's default window background color for current theme, InputWindow uses a custom one.
The problem is at h_controlmisc, line 3037:
If !ValType(aBackColor)="A"
   aBackColor  := {212,208,200}
Endif
Re: HMG 3.4.1
srvet_claudio wrote:
Roberto Lopez wrote:Claudio,
I've rebuilt the apps, with unicode version and it works fine now. So, the problem is limited to ANSI version.
Thanks for your help.
mol wrote:As I wrote....
Something is wrong with ANSI compilation
Marek and Roberto,
you are right, the problem is in ANSI, I will have to revise the code.
I think it is now fixed.
1) please unzip this file in source folder and re-build the lib
2) Use the solution proposed by Rathi.
Function main_query_server_action
   aRecordset := netio_funcexec( "query_001" , Main.Query_String.Value )
Main.Grid_1.ItemCount := 0   // <--  add this line
// Main.Grid_1.DeleteAllItems   // I think that this line is not necessary
   Main.Grid_1.ItemCount := LEN(aRecordset)
c_grid.rar
(5.48 KiB) Downloaded 337 times
Re: HMG 3.4.1
srvet_claudio wrote: I think it is now fixed.
Thanks!
I'll try it.
Re: HMG 3.4.1
Claudio,
Regarding InputWindow problem, I guess that the default background color should be:
GetSysColor(COLOR_WINDOW)
I've not tested yet.
Re: HMG 3.4.1 [EDITED]
Claudio,
About InputWIndow problem, this is the solution:
The code starting in line 3037 (h_controlmisc) must be replaced by:
	nColor := GetSysColor ( COLOR_BTNFACE )
	aBackColor := { GetRed(nColor) , GetGreen(nColor), GetBlue (nColor) }
Endif
Then, the default background color is correct (the same as the other windows).
In fact it should be COLOR_WINDOW (instead COLOR_BTNFACE), but is not working as expected here.
I'll try to test it on other Windows versions to be sure.
Re: HMG 3.4.1
It works perfect with ANSI and a simpler code:
THANKS!
Re: HMG 3.4.1
Endif
Endif
Many thanks Roberto,
I fixed, with this force to get the default color:
   aBackColor  := NIL
Endif
Re: HMG 3.4.1
   aBackColor  := NIL
Endif
Pretty much simpler... Thanks!
Re: HMG 3.4.1
Hi all,
1) please unzip this patch in folder c:\hmg.3.4.1
2) and rebuild the lib
- Fixed bug in CreateEvent (reporter by Roberto Lopez)
- Fixed bug in This.QueryData of Grid control (reporter by Roberto Lopez)
- Fixex bug in BackColor of InputWindow (reporter by Roberto Lopez)
- IsControlDefined, IsWindowDefine and IsWindowActive, accept parameters FormName/ControlName with/without quotation marks (contrib by Pablo Cesar)
hmg.3.4.1_patch1.rar
(820.73 KiB) Downloaded 691 times
Re: HMG 3.4.1
Thank you Dr. Claudio Soto for patch
