HFCL (Hmg Forum Component Library)
Source code related resources
Re: HFCL (Hmg Forum Component Library)
esgici wrote: Does your main.prg include #include "hfcl.ch" statement ?
Yes,
* MiniGUI Grid Demo
* (c) 2005 Roberto Lopez
#include "minigui.ch"
#include "hfcl.ch"
#define NTrim( n )   LTrim( TRAN( n,"999,999,999,999,999,999,999.99" ) )
Hfcl.ch contains
#include "combosearchbox.ch"
#include "gridprint.ch"
Gridprint.ch contains
#xcommand PRINT GRID <cGridName> ;
   OF <cParentName> ;
	[ FONT <cFontName> ]   ;
	[ SIZE <nFontSize> ]   ;
	[ ORIENTATION <cOrientation> ] ;
	[ HEADERS <aHeaders> ] ;
	[ <showwindow : SHOWWINDOW> ] ;
	[ MERGEHEADERS <aMergeHeaders> ] ;
	[ COLUMNSUM <aColumnSum> ] ;
	_GridPrint(<"cGridName">,<"cParentName">,<nFontSize>,<cOrientation>,<aHeaders>,<cFontName>,<.showwindow.>,<aMergeHeaders>,<aColumnSum>)
i_UsrSOOP.ch contains
#xcommand DECLARE CUSTOM COMPONENTS <Window> ;
_dummy() ;;
#define SOOP_MYBUTTON ;;
#xtranslate <Window> . \<Control\> . Print ( \<a1\> ) => Domethod ( <"Window">, \<"Control"\> , "Print", \<a1\>  )  ;;
#undef SOOP_MYBUTTON ;;
There must be something which I missed ;)
Actually, I want to use GridPrint in a project. :)
If I don't use semi-oop command, will the problem be solved?
TIA.
Hi Sudip
Please look at MiniAgenda; used in it GridPrind with semioop syntax.
Otherwise please send me your project.
esgici wrote: Please look at MiniAgenda; used in it GridPrind with semioop syntax.
It runs Ok, while semi-oop syntax is disabled :)
		DEFINE BUTTON BUTTON_1
		   ROW 340
		   COL 10
		   CAPTION "Print"
;//		   action form_1.grid_1.print({"Header1","Header2"})
    	   action doprint()
//		   ACTION _GridPrint("Grid_1","Form_1")
        END BUTTON
Where can I find MiniAgenda?
Regarding project, I want to use GridPrint for MyExpense project, which I published in this forum. GridPrint will be best suited for this project. I have a plan to publish it with with GridPrint today. In that case I have to use general syntax of GridPrint.
Thank you very much for helping me in the process of (re)-gaining self-confidence. :D
Sudip, Can you please send a small sample project?
Hello Rathi, Esgici,
rathinagiri wrote:Sudip, Can you please send a small sample project?
I just uploaded a small project with GridPrint in My Projects section. I added printing option into MyExpense project with GridPrint. But I can't use semi-oop syntax.
Here is it download/file.php?id=241
TIA.
Hi Rathi, Esgici,
My previous post's link downloads Setup file.
Please download source code for MyExpense from download/file.php?id=240
Thank you and I would do that. :)
sudip wrote: Where can I find MiniAgenda?
Top of topic : http://hmgforum.com/viewtopic.php?f=9&t=447#p3106
File to download : http://hmgforum.com/download/file.php?id=167
BTW, this sample include also incremental search in grid.
Hello Esgici,
esgici wrote: Top of topic : http://hmgforum.com/viewtopic.php?f=9&t=447#p3106
I downloaded it and compiled it. It is an excellent piece of software. I can learn many things from it. Again plan to use these concepts in my little project.
I missed this thread. But better late than never. Now I get it. :)
Thanks a lot!!! :)
Here is a new bug fixed, enhanced version of HFCL 0.92a. (2009.06.17)
hfcl.0.92a.zip
(38.51 KiB) Downloaded 890 times
Change Log:
GridPrint
1. Fixed: Show window command error
2. Fixed: When columns are summed up, column width is not calculated according to the total. Now, total is within the column width.
3. Changed: When column sum is used, number mask passed on is used for the whole column to be printed to make the column look uniform.
4. New: "Reset Form" button is added to reset the report configuration saved in the config file "reports.cfg".
