HMG 4 Started
Re: HMG 4 Started
Code changing colors should look like:
if ValType(::aFontColor) == 'U'
		xForeColor := '#000000;'
		xForeColor := '#'+NtoC(aFontColor[1],16,2)+NtoC(aFontColor[2],16,2)+NtoC(aFontColor[3],16,2)+';'
	cStyleSheet += 'color:'+xForeColor + ';'
	if ValType(::aBackColor) == 'A'
		cStyleSheet += 'background-color:#'+NtoC(aBackColor[1],16,2)+NtoC(aBackColor[2],16,2)+NtoC(aBackColor[3],16,2)+';'
	if !empty(cStyleSheet)
		::oQTObject:setStyleSheet(cStyleSheet)
but, while compiling, I get an error about not found function NTOC
I need simple conversion from numbers to hex to paste color in #RRGGBB format.
Re: HMG 4 Started
Excellent Marek :D Great :D
You got the answer :D
BTW, have you tried:
REQUEST NTOC
before calling NToC() function?
We are waiting for your solution.
There are some complex solutions I searched:
http://stackoverflow.com/questions/1777 ... ouble-spin
http://www.qtforum.org/article/23352/se ... idget.html
With Qt, we can do the same task in many ways. This is very good, but for a novice learner like me, it may be difficult ;)
Re: HMG 4 Started
looking for ntoc or rgb function in harbour source files, I found that xbpwindow.prg contains solution very similar to mine. So, I think, it could be right way :)
Re: HMG 4 Started
sudip wrote: BTW, have you tried:
REQUEST NTOC
REQUEST NTOC gives no solution :(
Still got an error while linking:
Generating C source output to 'c:\temp\hbmk_bksrao.dir\demo_11.c'... Done.
c:/temp/hbmk_bksrao.dir/demo_11.o:demo_11.c:(.data+0x1f08): undefined reference
to `HB_FUN_NTOC'
c:/temp/hbmk_bksrao.dir/demo_11.o:demo_11.c:(.data+0x1f58): undefined reference
to `HB_FUN_NTOC'
I think it's caused by missing library containing CA TOOLS functions - LIBHBCT.A.
It's strange - this lib file is preset at c:\hmg.4\harbour\lib\win\mingw, but linker can't find NTOC function.
I think Roberto should help us
Re: HMG 4 Started
Hello Marek,
Is following code helpful for decimal to hex conversion?
Function DecToHexStr(mInt)
	Local aTemp := {}, aRem := 0, mDiv := 0, sHex := '', ;
		lNegative := (mInt < 0)
	If lNegative
		mInt *= -1
	EndIf
	mRem := mInt
	Do While !Empty(mDiv := Int(mInt / 16) )
		mRem := Mod(mInt, 16)
		Aadd(aTemp, mDiv)
		mInt := mRem
	EndDo
	Aadd(aTemp, mRem)
	sHex := If( lNegative, '-', '')
	For i := 1 To len(aTemp)
		sHex += If(aTemp[i] > 9, Chr(65+aTemp[i]-10), LTrim(Str(aTemp[i])))
	Next
	RETURN (sHex)
I got Rgb() function in one of my old codes:
Function Rgb( r,g,b )
RETURN ( r + ( g * 256 ) + ( b * 256 * 256 ) )
I am not sure whether you are looking for this function. I am sorry, if you are looking for another function.
Again, thank you for your great work :)
Re: HMG 4 Started
I've copied numconv.prg from contrib\hbct
it contains conversion functions.
Thanks, Sudip
Re: HMG 4 Started
Roberto, is it possible to build sample with activated debugger?
When I've add -l option to build.bat, my app never appears on the screen and I must use task manager to kill it
Re: HMG 4 Started
Roberto Lopez wrote: Well... ..., so you do not need know C code at all.
Regarding OOP, I've created an extremely simple class hierarchy, so it should be 'understandable' for anyone, including those not familiarized with OOP, please, give it a try.
http://en.wikipedia.org/wiki/Object-ori ... rogramming
Thanks to encouraging and guidance :)
OK. I'll try..
That is being student afresh; this is scary but exciting ...
My sf.net user ID is esgici.
By the way, one of earliest web pages of HMG had a link to a site with very useful informations about OOP ;)
Best regards
Re: HMG 4 Started
mol wrote:Roberto, is it possible to build sample with activated debugger?
Regarding missing function, you could try to tell to hbmk2 to link the required library (-l parameter).
Regarding debugger, you could try adding -b parameter to hbmk2 and put a file called init.cld containing 'Options NoRunAtStartup' (without quotes).
This should do the trick.
Re: HMG 4 Started
OK. I'll try..
Best regards
I've got you access as developer.
Regarding OOP model I'm still having very much discrepancies with the way it is used.
I'm talking about simple applications, IMHO it is counter intuitive and difficult in such cases. It is like to use a bulldozer to make a small hole in your garden :)
This is the reason because I'm, still providing xBase and alternate syntax with public windows.
But, I must admit that when you are handling a very complex code, it can (in some cases) make the things easier.
I've started programming with BASIC. I've wrote large applications, plenty of GOTO statements creating truly spaghetti code. When I've started to learn dBase III+ I've was very upset because it hasn't GOTO.
My thinking was: 'I'm an adult, I'm responsible for my unconditional control transfers, please, let me do it' :)
The same applies to OOP. It is designed to try to avoid bad coding. Basically it tries to stop you to have problems with variables and code that can be reused.
This restrictions make difficult to do simple things but makes easier complicated ones.
And besides that, I'm proud to be a person that is not afraid to change my opinions.
We grow, we got more experience and knowledge, so, we become different, better persons. I have no problem with that.
IMHO to remain 'static' with the same ideas along all of your life is not a good thing.
