Welcome to the Project Developers' Table
Re: Welcome to the Project Developers' Table
Hi Roberto
had you checked with the new version of hbqt without constructor? Because i had changed the code from window.prg to dialogs.prg. Try to use with ::s_qApp:clipboard(). Now i am out of station and could not verify.
rathinagiri wrote:Hi Roberto
I'm testing HBIDE with current (10 minutes ago) Harbour sources.
bedipritpal
Post by bedipritpal »
Roberto Lopez wrote:
mrduck wrote:
I use xp pro sp3.
So, the only explanation to the fact that Pritpal was unable to reproduce the problem, is that for his system (like mine with the MingW QT SDK) the error does not arises on every execution but in a random basis.
Me too on XP Pro.
Hence because error does not arise on every execution,
It cannot be termed as error with QClipboard. Especially so because
error is reported in qtcore.dll while QClipboard() is a module of qtgui.dll.
So we need more tracing. It seems error is buries somewhere else.
As a tip, try to put traces before AND after call to QClipboard():setText( someText ).
bedipritpal
Roberto Lopez wrote:Pritpal,
There is another problem with current HBQT code (r 15658).
You can check it in testbrow.
When you edit a cell and confirm with [enter] the program ends.
When you restart the demo you'll notice that the position used to save was incorrect.
The problem is here:
STATIC PROCEDURE my_select( pModelIndex, nCX, nCY )
LOCAL qModelIndex := QModelIndexFromPointer( pModelIndex )
nCX := qModelIndex:column()
nCY := qModelIndex:row()
Since HMG browse is based on testbrow, the same problem arises on browse demos. The position retrieved from QModelIndex is incorrect.
Please verify after this changelog:
2010-10-21 12:51 UTC-0800 Pritpal Bedi (bedipritpal@hotmail.com)
* contrib/hbqt/qtcore/hbqt_hbqslots.cpp
+ Added: "QModelIndex,QModelIndex" constant.
* contrib/hbqt/tests/testbrow.prg
- Replaced: BREAK => EXIT.
Under such context, BREAK ( break; ) is a C statement not Harbour.
bedipritpal
You misread the ChangeLog.
QClipboard() returns a valid pointer but have not to be
released by GC. I just made it to not be freed by Harbour.
It is responsibility of Qt to free it.
So ::s_qApp:clipboard() and QClipboard() returns the same system clipboard.
bedipritpal
2010-10-21 13:04 UTC-0800 Pritpal Bedi (bedipritpal@hotmail.com)
* source/browse.prg
! Optimization.
Just do not pass variables to other methods if those are
declared as instance variables of the class.
bedipritpal wrote:Please verify after this changelog:
Is working fine now.
bedipritpal wrote:2010-10-21 13:04 UTC-0800 Pritpal Bedi (bedipritpal@hotmail.com)
* source/browse.prg
! Optimization.
You are right.
That comes from testbrow (function based) to browse class transition.
mrduck
Post by mrduck »
IMPORTANT:
hmg code must be updated for this change:
HB_*Class:from( pPtr ) => *ClassFromPointer( pPtr )
For example, run grid\demo_3.prg and try to edit a cell...
then change in grid.prg
METHOD DoCellKeyBoardEvents( e ) Class GRID
LOCAL oKeyEvent := QKeyEventFromPointer( e ) <--------here
here is a diff:
diff -r 3c2156624809 source/grid.prg
--- a/source/grid.prg Thu Oct 21 19:50:03 2010 +0200
+++ b/source/grid.prg Thu Oct 21 23:43:15 2010 +0200
@@ -251,7 +251,7 @@
ELSE // cellnavigation ON MultiSelect ON
oList := ::oQTObject:SelectedItems()
FOR i := 0 to oList:Size() - 1
- oItem := HB_QTableWidgetItem():from( oList:At( i ) )
+ oItem := QTableWidgetItemFromPointer( oList:At( i ) )
nRow := oItem:Row() + 1
nCol := oItem:Column() + 1
aAdd( aValue,{nRow,nCol} )
@@ -264,7 +264,7 @@
ELSE // cellnavigation OFF MultiSelect ON
IF aScan( aValue,nRow ) == 0
aAdd( aValue,nRow )
@@ -1539,7 +1539,7 @@
- LOCAL oKeyEvent := HB_QKeyEvent():from( e )
+ LOCAL oKeyEvent := QKeyEventFromPointer( e )
LOCAL nKey := oKeyEvent:key()
LOCAL nModifiers := oKeyEvent:modifiers()
LOCAL xValue
diff -r 3c2156624809 source/listbox.prg
--- a/source/listbox.prg Thu Oct 21 19:50:03 2010 +0200
+++ b/source/listbox.prg Thu Oct 21 23:43:15 2010 +0200
@@ -121,7 +121,7 @@
IF ValType( ::lMultiSelect ) != 'U' .and. ::lMultiSelect
FOR i := 0 to oList:size() - 1
- oLWItem := HB_QListWidgetItem():from( oList:at( i ) )
+ oLWItem := QListWidgetItemFromPointer( oList:at( i ) )
aAdd( aValue,::oQTObject:row( oLWItem ) + 1 )
NEXT i
RETURN aValue
diff -r 3c2156624809 source/window.prg
--- a/source/window.prg Thu Oct 21 19:50:03 2010 +0200
+++ b/source/window.prg Thu Oct 21 23:43:15 2010 +0200
@@ -1548,9 +1548,9 @@
IF valtype( ::oDropDownMenu:aItems ) == 'O'
IF valtype( ::oDropDownMenu:aItems:image ) == 'C'
- ::oDropDownMenu:aItems:oQTObject := QAction():from( ::oDropDownMenu:oQTObject:addAction( ::oDropDownMenu:aItems:image , ::oDropDownMenu:aItems:caption ) )
+ ::oDropDownMenu:aItems:oQTObject := QActionFromPointer( ::oDropDownMenu:oQTObject:addAction( ::oDropDownMenu:aItems:image , ::oDropDownMenu:aItems:caption ) )
- ::oDropDownMenu:aItems:oQTObject := QAction():from( ::oDropDownMenu:oQTObject:addAction( "" , ::oDropDownMenu:aItems:caption ) )
+ ::oDropDownMenu:aItems[i]:oQTObject := QActionFromPointer( ::oDropDownMenu:oQTObject:addAction( "" , ::oDropDownMenu:aItems[i]:caption ) )
IF valtype( ::oDropDownMenu:aItems[i]:enabled ) == 'L'
@@ -1748,7 +1748,7 @@
::oQTObject:setContextMenuPolicy( 3 )
- ::oQTObject:connect( "customContextMenuRequested(QPoint)", {|p| ::oContextMenu:oQTObject:exec( ::oQTObject:mapToGlobal( QPoint():from( p ) ) ) } )
+ ::oQTObject:connect( "customContextMenuRequested(QPoint)", {|p| ::oContextMenu:oQTObject:exec( ::oQTObject:mapToGlobal( QPointFromPointer( p ) ) ) } )
Pritpal,
I've found another problem after conversion.
Print text alignment is not working anymore.
The relevant code is between lines #669 to #679 in printer.prg:
         IF valtype( nToRow )=='N' .and. valtype( nToCol )=='N'
            QRectF := QRectF( nCol , nRow , nToCol - nCol , nToRow - nRow )
            QTextOption := QTextOption()
            IF valtype( nAlignment ) == 'N'
               QTextOption:setAlignment( nAlignment )
               QTextOption:setAlignment( 0 )
            ::qPainter:drawText( QRectF , cData , QTextOption )
