Welcome to the Project Developers' Table
Re: Welcome to the Project Developers' Table
mrduck wrote:Please reapply the code of clipboard, so that we can more easily understand which is the error...
METHOD Clipboard( cValue ) CLASS WINDOW
IF ::oClipboard == NIL <<<<<< this code may be moved to window.prg ???
::oClipboard := ::s_qApp:clipboard()
IF PCount() == 0
RETURN ::oClipboard:text( 0 )
::oClipboard:setText( cValue, 0 )
oClipboard must be defined in class application, since it is a singleton anyway
Hi, I have changed clipboard functionality to dialogs.prg since clipboard is system specific and not window specific. Please see this code in /samples/misc/demo_1.prg
This is the function. Even now it gives the same GPF error.
FUNCTION SetClipboardValue( cValue )
   LOCAL qClip
   qClip := QClipboard()
   qClip:clear()
   qClip:setText( cValue )
bedipritpal
Post by bedipritpal »
Roberto Lopez wrote:Can this be caused because I'm using QT 4.7?
Using exactly the same environment, I've switched to QT 4.5.3 and HBIDE was successfully built.
And it could be a problem with MingW.
I'll try QT 4.7 again switching to a newer MingW version.
Yes, MinGW.
Read INSTALL.
bedipritpal
rathinagiri wrote: This is the function. Even now it gives the same GPF error.
   LOCAL qClip
   qClip:clear()
Look into contrib/hbide/ideedit.prg
where this function is used. You must be doing something wrong
somewhere in class hirarchy. Try to put trace for cValue before/after :setText()
is called. Error is buried somewhere not visible.
Ok Pritpal. I will try and let you know about the results. Thanks.
Also I noted the following:
When a clipboard value is copied from other applications and used demo_1 to set clipboard value, the program is not crashed and exits normally.
However, when we use again demo_1 to set clipboard value, it crashes.
So, whenever we re-set the clipboard value from QT, the program crashes.
Hi Pritpal,
I have verified. HBIDE is also giving the same error. :(
Will it be anyway related to Windows 7 UIPermission for Clipboard activities? But, I have run the program as administrator too.
mrduck
Post by mrduck »
   LOCAL qClip
   qClip:clear()
I believe this code is wrong, since, according to docs, "There is a single QClipboard object in a application, accessible as QApplication::clipboard()"
so the method
IF PCount() == 0
should be better suited...
Using QClipboard() constructor is not present in Qt documentation !
Next, we can study the reason of the error.
Only after reading the docs and examples in the net, I had used QClipboard as ::s_qApp:QClipbaord()
Since Pritpal advised to use QClipboard() constructor, I have used that. Now, both the implementations give the same error. Even the error occurs in HBIDE editor too.
bedipritpal
rathinagiri wrote:Since Pritpal advised to use QClipboard() constructor, I have used that. Now, both the implementations give the same error. Even the error occurs in HBIDE editor too.
I never got such error.
Can you give me steps to reproduce ?
Chances are it will be fixed.
My systems are Windows 7 and Vista Home edition. It happens from the first time itself in the case of Win 7 and from the second time onwards in the case of Vista.
Open HBIDE editor. Type something. Select the text. Right Click. Select Copy. Close HBIDE. The error appears.
Here is the screenshot.
Roberto Lopez wrote:I'll try QT 4.7 again switching to a newer MingW version.
Yes, MinGW.
Read INSTALL.
Yes, it is.
I'll create new binaries including HBIDE ASAP.
Thanks.
