Welcome to the Project Developers' Table
mrduck
Re: Welcome to the Project Developers' Table
Post by mrduck »
Please reapply the code of clipboard, so that we can more easily understand which is the error...
METHOD Clipboard( cValue ) CLASS WINDOW
IF ::oClipboard == NIL <<<<<< this code may be moved to window.prg ???
::oClipboard := ::s_qApp:clipboard()
IF PCount() == 0
RETURN ::oClipboard:text( 0 )
::oClipboard:setText( cValue, 0 )
oClipboard must be defined in class application, since it is a singleton anyway
mrduck wrote: Roberto, I ask you to read that page. It is generic and I think it is important to know
I'll eventually read it, but despite that, I'll invite you that when you think that something must be changed, please, present us your proposed changes and the reasons to do that. we'll discuss it and if the reasons are valid, we'll do it.
Pritpal,
I've built Harbour from sources from the last three days and I've just noted that hbide was not built.
In all cases all hbqt libraries (and all other things ) were built right and are working fine.
There is some new requirement to build HBIDE?
TIA.
Roberto Lopez wrote:Pritpal,
TIA.
My environment:
- MingW 4.4.1
- QT 4.7
- Harbour Nightly sources from last three days.
My build batch file:
set path=c:\mingw\bin
set HB_WITH_QT=C:\Qt\4.7.0\include
set HB_INSTALL_PREFIX=c:\hmg.4\harbour
mingw32-make install
bedipritpal
Post by bedipritpal »
TIA.
No, why it is not built ?
I mean what error message or something like.
BTW it is now part of Harbour binaries.
bedipritpal wrote:No, why it is not built ?
Build takes a long time and it generates a lot of screen messages.
I'll rebuild and try to catch a messages that can give me some info or find some log that can help.
Thanks.
bedipritpal wrote: No, why it is not built ?
Here it is.
I've got multiple messages:
'undefined reference to `_Unwind_Resume'
Can this be caused because I'm using QT 4.7?
Roberto Lopez wrote:Can this be caused because I'm using QT 4.7?
Using exactly the same environment, I've switched to QT 4.5.3 and HBIDE was successfully built.
And it could be a problem with MingW.
I'll try QT 4.7 again switching to a newer MingW version.
2010-10-20 09:20 UTC+0530 Rathinagiri (srgiri@dataone.in)
* /source/window.prg
! Fixed Self:DoKeyboardEvents(). This function now returns a logical value. Thanks to Francesco.
Now, the user can return a logical value either to accept and close the event by returning 'true' or to ignore it and let it propagate to the parent by returning 'false'. If no logical value is returned, it is assumed that 'false' is returned.
