The Future!
Re: The Future!
It's not abandoned.
The community hasn't shown much interest and I have too much private work.
And there's one more thing needed to have hbtron 100%
It's a link router like the one in VUE., for better workflow control.
It will come tho.
It will come tho.
Angel Pais
Re: The Future!
[SPANISH]
Anuncio: El ecosistema Harbour tiene un nuevo integrante.
En docker hub, hay un docker Ubuntu Linux con hw_apache y MySQL client.
https://hub.docker.com/r/diegofazio/hw_apache
Un click y a correr tus Web Apps a toda velocidad!
Con esta imagen de tan solo 84MB, tienes hw_apache instalado y funcionando en sólo minutos.
No mas problemas con dependencias o configuración.
100% Plug and Play.
Y hay más!
Estamos probando, una imagen específica para servidores Amazon ECS/Fargate.
[ENGLISH]
Announcement: The Harbour ecosystem has a new member.
On docker hub, there's a docker Ubuntu Linux with hw_apache and MySQL client.
One click and run your Web Apps at full speed!
With this image of just 84MB, you have hw_apache up and running in just minutes.
No more problems with dependencies or configuration.
100% Plug and Play.
And there is more!
100% Plug and Play.
Y hay más!
[ENGLISH]
100% Plug and Play.
And there is more!
Angel Pais
Re: The Future!
[ENGLISH]
From the creators of hbtron, hw_apache, and hw_apachews:
Another way of mixing harbour and Html code !
HBWUI ( Harbour Web User Interfases ).
A WebView2/Cocoa/GTK Harbour Web UI implementation.
Multiplatform Harbour GUI programs made in Html/CSS and just a bit of js
With this, you can build Html interfaces for your programs and from them interact with your .exe
Just 2 functions that will turn your world upside down.
In a harbour .exe:
hbwui_Init( cUrl, cTitle, nWidth, nHeight, lFullscreen, lResizable, lMaximized, lDebug )
In a UI html module:
windows.external.invoke( cStr )
Make your WIN/LIN/MAC apps run the most universal UI: Html/CSS/JS.
No more wrappers, no more intricate class hierarchies, no more vendor dependency.
Only your imagination is the limit!
Download and test it from:
https://github.com/diegofazio/hbwui
It's free!
[ESPAÑOL]
De los creadores de hbtron, hw_apache y hw_apachews:
¡Otra forma de mezclar código puerto y HTML!
Una implementación de interfaz de usuario WebView2 / Cocoa / GTK Harbour.
Programas multiplataforma Harbour GUI hechos en Html / CSS y solo un poco de JS
Con esto, se puede construir interfaces Html para sus programas y desde ellos interactuar con su .exe
Solo 2 funciones que pondrán tu mundo patas arriba.
En un .exe de Harbour:
hbwui_Init (cUrl, cTitle, nWidth, nHeight, lFullscreen, lResizable, lMaximized, lDebug)
En un módulo Html de la interfaz de usuario:
windows.external.invoke (cStr)
Haga que sus aplicaciones WIN / LIN / MAC ejecuten la interfaz de usuario más universal: Html / CSS / JS.
No más envoltorios, no más jerarquías de clases intrincadas, no más dependencia de proveedores.
¡Solo tu imaginación es el límite!
Descárgalo y pruébalo desde:
¡Es gratis!
In a harbour .exe:
It's free!
[ESPAÑOL]
¡Es gratis!
Angel Pais
- luisvasquezcl
Re: The Future!
Estimado Ángel, espero que haya algo de documentación para ir haciendo pruebas.
Gracias
Gracias
Re: The Future!
Hay 2 ejemplos. Uno para cada funcion. Es solo compilarlos.
Cada prg de ejemplo tiene la documentacion de las funciones nuevas (son solo 2).
Las libs por ahora son solo para msvc.
Estamos trabajando en ampliar el rango de funciones, ya que es un juguete nuevo que hicimos hace recien una semana.
Pero aun con esto ya se pueden hacer cosas muy interesantes.
Por ej. lanzar un informe en html desde tu .exe HMG sin necesitar un server ni internet siquiera para ello.
Angel Pais
- luisvasquezcl
Re: The Future!
Ok, gracias.
Re: The Future!
That looks promising. Let me check out. Thanks!
Re: The Future!
Muchas Gracias Sr Angel.
Lo probaré.
Lo probaré.
Re: The Future!
Hola Ángel,
Saludos,
Javier
Por el momento para alguna prueba con mingw no es posible aun, correcto?
Saludos,
Javier
Re: The Future!
Aun no. Y mi colega Diego se tomo un par de semanas de vacaciones.
A su vuelta veremos que hacer a futuro.
Angel Pais
