Project Free HRD & Payroll Application
Re: Project Free HRD & Payroll Application
Agil Abdullah wrote:For Roberto Lopez,,,
I tried to execute your above sample codes for connecting Server NETIO. But, error found like this screenshoot. May be, codes I modified made some mistakes. Pls kindly help.
My sample is a pure Harbour console application (not an HMG one).
So, you must remove the #include 'hmg.ch'.
To assure that the correct build configuration is used, you must download Harbour compiler and install (ie) in c:\hb32.
Then, go to c:\hb32\contrib\hbnetio\tests and create your sample there, by typing:
c:\hb32\bin\hbmk2 prgname
Then, It will work.
Agil Abdullah
Post by Agil Abdullah »
Many thanks for attention of Serge Girard & Roberto Lopez. I'll try to exercise with NETIO.
So, I need to download Harbour first. When I find it in trouble I'll ask for your help. :)
Programmer Never Surrender
Agil Abdullah
Till today, I just finished designing forms of dataentry for 3 Master Tables (Company, Unit, Department).
NOTE, Especially for my friends in my country Indonesia: We've been through with a lot of exercises, with SAMPLES availables and tests on friends' shares (attachments) in this forum. Now it's about time for us to try to start with our own style. A style in handling with Dataentry and display related to it.
As shown on this screenshoot.... An Exercise to design with Twin-Window template (inspired by Dr.Claudio Soto's mirror-window) & SplitBox. Attachement will follow.
Salam Hangat dari Jakarta. :D
Agil Abdullah
Today I report that I've completed a Master Table Dataentry with source-progs attached below. In general what I need to say are... (let me copy from Menu:Help-About) as follows:
This sample (and simple) program is built with HMG.3.3.1, intended to do exercises with & implement the followings:-"
0] Getting accustomed to behavior of & handling with the Controls, Properties, Methods, Events: Characteristic of GUI codes."
"1] Presenting Data entry for 3 Master Tables: Company, Unit, Department."
"2] Arranged 3 grids within one window, organized in splitbox manner."
"3] The grids are positioned at half below, look similiar to the way the MS-Exel Sheets work."
"4] Above them are living panel windows, showing full data within a grid-cells where pointers sitting in."
" Each Window Template belonging to each table is loaded twice as twin form: "
" one form for Dataentry[read-write], the other for Display [readonly]."
" User choice to Accept or Cancel entry is placed at buttons within template-entry, not outside."
" When entry-time on stage, Form-Entry shows."
" When user press GO-button, Form-Entry releases itsself, Form-Display takes over the job."
" Form-Entry only do its job when entry time on stage, the rest belongs to Form-Display's showtime."
"6] Users are able to edit only one table at a time, or enable all the 3 to edit at the same time."
"7] The dataentry implements classic [but half strict] rules to maintain data integrity, which are:"
" - Once a record is added/appended, it is prohibited to modify Keyfields (Company-code, unit-code, deptcode)"
" - This rule to guarantee that database is under control, users has no opportunity to play with codes"
" - If something wrong happends to the codes, users should delete it, then append new one"
" - This rule will enable historycal records to be added, to examine how dataentry is treated by users."
" - This rule to prevent any accidental[unpredictable] edit to codes, especially in network environment."
"8] Keyfield of Company ->[compcode], protected in Company-Update operation."
" Keyfield of Unit ->[compcode+unitcode], Unitcode is protected in Unit-Update Operation."
" Keyfield of Department->[compcode+unitcode]+[deptcode], Deptcode is protected in Dept-Update Operation."
"9] Grids contain of records from Databases which are sent by way of RecordSet as recommended by Roberto Lopez."
" This is in preparation to implement NETIO Client-Server: no live data directly in grid, use RecordSet instead."
"10] This sample is part of Project Free HRD & Payroll, scheduled to be ready to install in full in January 2015."
" Free to copy/share/modify, etc."
"Many thanks to help & support from HMGforum friends: Rathinagiri, Roberto Lopez, Serge Girard, BPD2000, Mustafa, Esgici."
"06-Nov-2014, "
"Agil Abdullah Albatati, Jakarta Indonesia, email: agil1960dcr@yahoo.com" + CRLF + ;
"(beginner to HMG)
>>>> Attachment see next page---->
Note: you may place the sample/demo in any folder. Have a try and give your comments/advise/revision & whatever, if you wish.
Regards,,,,,
Agil Abdullah
This source is with MainProgram placed in "Demo.prg"
MultiGrid.rar
(188.96 KiB) Downloaded 711 times
Agil Abdullah
and this the last update dataentry design with template.
Agil Abdullah
and this one is my exercises with Modify DataStructure, View DataStructure, PackFile... You may find them at Menu-File.
In brief, you're easy to find the filenames, the structures, etc without running DBU utility or its kind because all written in my codes. See Mandbf01.prg, Mandbf02, Mandbf03. I try not to leave dark spots to users concerncing the dbf/tables.
