Page 8 of 15
edit (R)extended
Posted: Wed May 29, 2013 8:56 pm
t57042 wrote:The language selection doesn't seem to work here.
I tried to set it with HB_LANGSELECT in the sourcecode and with the 'language select' option in the menu.
Always get english.
How does it work?
I have passed recentely with same case. Just to change languages in C:\hmg.3.1.3\SAMPLES\EDIT_EXTENDED\demo.prg, you have to add InitMessages( aLangID[nItem] ) after line where is HB_LANGSELECT( aLangID[nItem] ), then it will work fine ! :)
At begining you can set you local language, but remeber must be both lines:
Alias better than the both lines, just put SET LANGUAGE TO FRENCH (for example).
edit (R)extended
Posted: Wed May 29, 2013 9:11 pm
My good question is:
Are someone still using EDIT EXTENDED ?
Compensates to make new implements in EDIT EXTENDED if no one uses ?
I feel missing features like as:
- Possibility to assign user function: OnChange, OnEnter, OnGotFocus and OnLostFocus events or new event just to "valid" each field in edition.
- Possibility to define ComboBox in place of TextBox (dificult assign, but I believe possible)
Re: edit (R)extended
Posted: Wed May 29, 2013 9:52 pm
by srvet_claudio
Pablo César wrote:Are someone still using EDIT EXTENDED ?
Re: Edit Extended
Posted: Thu May 30, 2013 12:19 am
by Gustavo Romo
I have the same problem,
the Languaje still in English in Edit Extended,
SET LANGUAGE TO SPANISH
SET CODEPAGE TO SPANISH
InitMessages( "ES" )
HB_LANGSELECT( "ES" )
Don't Work
Yo tengo el mismo problema al USAR EDIT O EDIT EXTENDED
Todos los botones aparecen en ingles a pesar de iniciar tu procedimiento con las órdenes arriba indicadas
Saludos a todos!
Edit Extended
Posted: Thu May 30, 2013 1:20 am
Gustavo Romo wrote:the Languaje still in English in Edit Extended,
Gustavo, your indication is totally different as I have suggested. Please note this example:
#define APP_TITLE    "EDIT EXTENDED Demo"
Function Main()
SET CENTURY ON
SET DELETED OFF
SET DATE TO BRITISH
// SET LANGUAGE TO PORTUGUESE
// InitMessages("PT")
// SET CODEPAGE TO SPANISH
// HB_LANGSELECT( "ES" )
DEFINE WINDOW Win_1                  ;
   AT         0,0                    ;
   WIDTH      getdesktopWidth()      ;
   HEIGHT     getDeskTopHeight()-27  ;
   TITLE      APP_TITLE              ;
   MAIN                              ;
   NOMAXIMIZE                        ;
   NOSIZE                            ;
   ON INIT    OpenTable()            ;
   ON RELEASE CloseTable()
   DEFINE BUTTON Button_1
        ROW    250
        COL    240
        WIDTH  100
        HEIGHT 28
        ACTION BasicDemo( "TEST2" )
        CAPTION "Editar DBF"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
ACTIVATE WINDOW Win_1
return NIL
Function OpenTable()
// USE TEST2 Shared
If !Open_Dbf("TEST2.DBF", .f., .f., "TEST2", "DBFNTX")
   MsgStop("Não foi possível abrir o arquivo: TEST2.DBF")
Endif
if !File( "TEST2COM.NTX" )
   // Create order by first field plus last field.
   // You can't search by this order. Only for test.
   TEST2->( ordCreate( "TEST2COM.NTX",                     ;
                       "First Name",                       ;
                       "TEST2->First + TEST2->Last",       ;
                       {|| TEST2->First  + TEST2->Last } ) )
if !File( "TEST2LAS.NTX" )
   // Create order by last field.
   TEST2->( ordCreate( "TEST2LAS.NTX",                     ;
                       "Last Name",                        ;
                       "TEST2->Last",                      ;
                       {|| TEST2->Last } ) )
if !File( "TEST2HIR.NTX" )
   // Create order by hiredate field.
   TEST2->( ordCreate( "TEST2HIR.NTX",                     ;
                       "Hire Date",                        ;
                       "TEST2->Hiredate",                  ;
                       {|| TEST2->Hiredate } ) )
if !File( "TEST2AGE.NTX" )
   // Create order by age field.
   TEST2->( ordCreate( "TEST2AGE.NTX",                     ;
                       "Age",                              ;
                       "TEST2->Age",                       ;
                       {|| TEST2->Age } ) )
if !File( "TEST2MAR.NTX" )
   // Create order by.
   TEST2->( ordCreate( "TEST2MAR.NTX",                     ;
                       "Married",                          ;
                       "TEST2->Married",                   ;
                       {|| TEST2->Married } ) )
TEST2->( ordListAdd( "TEST2COM.NTX", "Primeiro Nomes" ) )
TEST2->( ordListAdd( "TEST2LAS.NTX", "Sobre Nomes" ) )
TEST2->( ordListAdd( "TEST2HIR.NTX", "Data de aluguel" ) )
TEST2->( ordListAdd( "TEST2AGE.NTX", "Idade" ) )
TEST2->( ordListAdd( "TEST2MAR.NTX", "Casado" ) )
TEST2->( ordSetFocus( 1 ) )
Function Open_Dbf(cDbfName, lUseExclusive, lReadonly, cAlias, cRddName, nTries, lAsk)
Local nTriesOrig, lReturn:=.f., lNewArea:=.t.
DEFAULT lNewArea:=.t.
DEFAULT lReadonly:=.f.
DEFAULT lAsk:=.t.
DEFAULT nTries:=5
DEFAULT cRddName:="DBFNTX"
nTriesOrig := nTries
Do While nTries > 0
   DbUseArea(lNewArea,cRddName,cDbfName,cAlias,!lUseExclusive,lReadonly)
   If (!NetErr()) .and. Used()
      lReturn := .t.
      Exit
   Endif
   Inkey(.5)
   nTries--
   If nTries = 0 .and. lAsk
      If MsgRetryCancel(aLng[027]+cDbfName+aLng[143]+CRLF+aLng[144],aLng[145])
         nTries := nTriesOrig
      Endif
   Endif
Enddo
Return lReturn
Function CloseTable()
CLOSE TEST2
Function BasicDemo( cArea )
Local aFieldName   := { "Primeiro Nome", "Sobrenome", "Endereço", "Cidade", ;
                       "Estado", "CEP", "Data Aluguel", "Casado", "Idade", ;
                       "Salário", "Observações" }
Local aFieldAdvise := { "Digite o primeiro nome",                ;
                       "Digite o sobrenome",                    ;
                       "Digite o endereço onde mora",           ;
                       "Digite a cidade onde mora",             ;
                       "Digite o estado (em dois caracteres)",  ;
                       "Entre com o código postal",             ;
                       "Selecione a data de aluguel",           ;
                       "Deixe marcado se for casado",           ;
                       "Entre com a idade",                     ;
                       "Entre com o salário",                   ;
                       "Deixe alguma observação, se for necessário" }
Local aVisTable    := { .t., .t., .t., .t., .f., .f., .f., .f., .t., .t., .f. }
Local aFieldEdit   := { .t., .t., .t., .t., .t., .t., .t., .t., .t., .f., .t. }
Local aOptions     := Array( 3, 2 )
Local bSave        := {|aValues, lNew| Salvar( aValues, lNew, cArea ) }
Local bSearch      := {|| MsgInfo( "Sua rotina de pesquiça" ) }
Local bPrint       := {|| MsgInfo( "Sua rotina para imprimir" ) }
aOptions[1,1] := "Executa opção 1"
aOptions[1,2] := {|| MsgInfo( "Você pode fazer a sua rotina 1" ) }
aOptions[2,1] := "Executa opção 2"
aOptions[2,2] := { || MsgInfo( "Você pode fazer a sua rotina 2" ) }
aOptions[3,1] := "Execute opção 3"
aOptions[3,2] := { || MsgInfo( "Você pode fazer a sua rotina 3" ) }
EDIT EXTENDED WORKAREA &cArea      ;
	TITLE "Employees maintenance" ;
    FIELDNAMES aFieldName         ;
	FIELDMESSAGES aFieldAdvise    ;
    FIELDENABLED aFieldEdit       ;
    TABLEVIEW aVisTable           ;
    OPTIONS aOptions              ;
    ON SAVE bSave                 ;
    ON FIND bSearch               ;
    ON PRINT bPrint
Function Salvar( aValues, lNew, cArea )
Local i := 1
If Empty( aValues[1] )   // Primeiro nome
   MsgInfo( "O nome não pode estar em branco !" )
   Return .f.
Endif
// Calcula o salario
aValues[10] := 100.5
// Salva o registro
If lNew
   (cArea)->( dbAppend() )
Endif
For i := 1 TO Len( aValues )
   (cArea)->( FieldPut( i, aValues[i] ) )
Next
Return .t.
Please return if your tests was made with sucess, otherwise I can send my executable file to prove that is working the way I have indicated.
You can make this PRG in C:\hmg.3.1.3\SAMPLES\EDIT_EXTENDED folder just for testing.
Re: Edit Extended
Posted: Thu May 30, 2013 2:27 pm
by Gustavo Romo
Pablo Cesar
My problem is my .bat
when I compile with build.bat your application runs in LANGUAGE correctly
when use my bat, the same problem still remain: language in English
Can you help me, I use minigui extended in my aplication
Mi problema es el bat que utilizo, cuando corro tu ejemplo con el build.bat la aplicacion esta en español
pero cuando lo corro con mi bat, (que adjunto) aparece nuevamente en ingles.
La situación es que no puedo utilizar build.bat porque uso minigui ya que uso mucho tsbrowse
gracias, podrias echarle un ojo a mi bat:
@echo off
SET HMGPATH=C:\hmg.3.1.2
SET HMGRPATH=C:\minigui
echo #define HMGRPATH %HMGRPATH%\RESOURCES > _hmg_resconfig.h
COPY /b %HMGRPATH%\resources\hmg.rc+%1.rc+%HMGRPATH%\resources\filler _temp.rc >>NUL
windres -i _temp.rc -o _temp.o
HBMK2 %1 %2 %3 %4 %5 %6 %7 %8 %HMGRPATH%\minigui.hbc -run
del _hmg_resconfig.h
del _temp.*
Re: Edit Extended
Posted: Thu May 30, 2013 5:42 pm
The second HMGPATH nullifies the first HMGPATH.
Re: Edit Extended
Posted: Fri May 31, 2013 1:46 pm
by Gustavo Romo
there are diferent hmgRpath and hmgpath, if I remove one of them, can't compile my application
I can't use HMG and Minigui at the same time, with other .bat,
No se compilar HMG con Minigui con otro bat, seguramente es mi .bat el que enlaza de tal manera que el edit extended
permanezca en idioma inglés.
Edit Extended
Posted: Fri May 31, 2013 5:24 pm
Gustavo Romo wrote:seguramente es mi .bat el que enlaza de tal manera que el edit extended permanezca en idioma inglés.
Compilé en Minigui puro y el resultado se mostró perfecto para mi, fijate:
En verdad no tengo experiencia alguna con mezclar HMG y Extended. Tenés alguna razón de mantenerte con Extended ? No puedes pasar al HMG ?
Compiled in MiniGUI pure and the result was perfect for me and pls note:
In truth I have no experience whatsoever with HMG and Extended mix. You have any reason to stay with Extended? You can not go to HMG?
Re: Edit Extended
Posted: Fri May 31, 2013 6:14 pm
by Gustavo Romo
Si de hecho compile el ejemplo y me funcionó perfectamente, pero el .bat marca error al tratar de usarlo en mi aplicacion.
Se que tu ejemplo funciona perfectamente, gracias, por eso me di cuenta que e error es la mezcla entre HMG y Minigui
Lo único que utilizo en minigui es TSbrowse por que me permite editar campos y que el cursor se mueva donde yo lo deseo. (no conozco que Grid pueda hacer eso) -a mi me encanta usar grid y usar arrays
Gracias por tu tiempo y apoyo
P.D. Dato curioso Fijate que si uso en lugar de HBMK2 utilizo Borland, se corrige el problema, pero se tarda mucho en compilar
